Please HELP! Injectors wont fit???
Old Sep 4, 2010 | 04:16 PM
Luke G.'s Avatar
Default Please HELP! Injectors wont fit???
i am installing precision 650cc saturated injectors. This is an obd1 gsr engine. The problem is when i go to put them in the injector clips they only go half way and then stop. While the stock ones go in perfectly. They look almost exactly the same besides a small plastic piece in the middle of the 650cc injector clip part. Any info will be very helpful. Thanks.
Old Sep 4, 2010 | 04:34 PM
jetspeedz's Avatar
Default Re: Please HELP! Injectors wont fit???
you can cut that clip out or get a harness either will work. If you don't have a decent set of dikes you can use a blade and cut it out. good luck
Old Sep 4, 2010 | 04:35 PM
Luke G.'s Avatar
shouldnt it just be plug and play though?
Old Sep 4, 2010 | 04:39 PM
jetspeedz's Avatar
if they are obd1 style clips yes
Old Sep 4, 2010 | 04:40 PM
Luke G.'s Avatar
they are obd1 clips. I just tried plugging them into my obd1 d15 clips and they did the same thing.
Old Sep 4, 2010 | 04:42 PM
jetspeedz's Avatar
im telling you just cut that little plastic piece out and it will work, or you have to end up getting a harness, went through this with RC injectors also before i switched to ID
Old Sep 4, 2010 | 04:43 PM
Luke G.'s Avatar
alright, i'll try that. Thanks
Old Sep 4, 2010 | 04:45 PM
jetspeedz's Avatar
cheers
Old Sep 4, 2010 | 04:47 PM
Luke G.'s Avatar
Hell yea. Just cut one and it fits perfect. Thanks a lot!
Old Sep 4, 2010 | 04:49 PM
jetspeedz's Avatar
no prob, just make sure you have a good base map for those
Old Sep 4, 2010 | 05:14 PM
Luke G.'s Avatar
getting pro tuned the end of next week
killerpenguin21
May 2, 2010 11:51 AM
00Red_SiR
Apr 27, 2008 08:19 AM
97turboteg
Apr 25, 2006 03:56 PM
BoOsTiN Dc2
Apr 14, 2005 03:31 AM
ladysman
May 26, 2003 01:50 PM
