PLEASE HELP!! HONDATA W/ MAP SENSOR???
Old Jan 2, 2004 | 02:12 AM
oemDC2's Avatar
Default PLEASE HELP!! HONDATA W/ MAP SENSOR???
I was just waondering if i needed to have map sensor bypass valves if I'm running a hondata s200b?? Will i throw any CELs with hondata?
Old Jan 2, 2004 | 04:53 AM
ladysman's Avatar
Default Re: PLEASE HELP!! HONDATA W/ MAP SENSOR??? (oemDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oemDC2 &raquo;</TD></TR><TR><TD CLASS="quote">I was just waondering if i needed to have map sensor bypass valves if I'm running a hondata s200b?? Will i throw any CELs with hondata?</TD></TR></TABLE>
Nothing needed with a Hondata S200b setup. It takes care of all that for you. it likes boost.
Old Jan 2, 2004 | 05:17 AM
onetwothree's Avatar
Default Re: PLEASE HELP!! HONDATA W/ MAP SENSOR??? (ladysman)
Taken str8 from Hondata.com
"How much boost can I run with a Hondata ECU?
The stock MAP sensor can see 11 lbs boost. If you replace the MAP sensor with a 3 bar MAP sensor you can run 28 lbs boost."
Old Jan 2, 2004 | 10:45 AM
oemDC2's Avatar
Default Re: PLEASE HELP!! HONDATA W/ MAP SENSOR??? (onetwothree)
sweet.. thanks.. Oh yeah...Whats the push button that came with mt hondata for? and it also came with 2-3 chips (base maps???). How do i install those?
Old Jan 5, 2004 | 09:45 AM
Spunkster's Avatar
http://www.hondata.com/downloa...l.doc
http://www.hondata.com/downloa...e.doc
Freshdot
Engine Management and Tuning
Mar 13, 2011 03:23 PM
Dave_yd
Mar 24, 2008 12:57 PM
