please help hondata question
Old Dec 1, 2002 | 10:35 PM
1SpoolnH's Avatar
Default please help hondata question
ok i want to get hondata but i want to make sure its what i want. i have and sohc turbo and i have check valves now. if i get the hondata do i still need the check valves and the vortech fmu or does it replace these. also will you still through a cel if you boost at cell level from the map sensor. or will it take that problem out. please any info will be usefull.
Old Dec 2, 2002 | 02:54 AM
ekb18c's Avatar
Default Re: please help hondata question (1SpoolnH)
You will not need the check valves with hondata. You can throw away the fmu also. And you will not throw any CEL's if you boost. However you will be limited to 11.3 psi, but if you want to boost more then that you will need to get a GM 3 bar map.
BoOsTiN Dc2
Jan 20, 2005 02:14 PM
SiBirdie
Jun 5, 2004 11:49 AM
JusT a Cx
May 24, 2004 03:35 PM
Goldfingiz
Dec 16, 2002 12:26 AM
1SpoolnH
Nov 24, 2002 09:44 PM
