Please help DIY intercooler piping on integra
Old Nov 17, 2004 | 07:43 AM
Corinthians's Avatar
Default Please help DIY intercooler piping on integra
Please help me my computer is format and i lost the web page of a very good diy intercooler piping for integra anyone? Please let me know.
Old Nov 17, 2004 | 08:10 AM
tilt's Avatar
Default Re: Please help DIY intercooler piping on integra (Corinthians)
http://www.cse.uconn.edu/~yele....html
Old Nov 17, 2004 | 08:14 AM
PM-Performance's Avatar
not what your looking for , but this is a Dope *** PIping set up . Never blew a pipe off and used cheap hose clamps not even TBolts
This user should get an A+ for Fabrication
Old Nov 17, 2004 | 10:23 AM
RyanEJ8's Avatar
At work right now, but I have a real good link in my favorites on my PC at home. I'll post up the link when I get home tonight.
Old Nov 17, 2004 | 12:15 PM
adseguy's Avatar
Default Re: Please help DIY intercooler piping on integra (RyanCivic2000)
I went to jcwhitney.com and order 3 12" 180 degree ubends of their 2.5" aluminized mandrel bends and 1 24" 180 degree u bend. I went ahead and marked and cut the pieces with a 24 TPI blade and a saw zaw. If the piece didn't fit correctly I just kept cutting making sure I didn't cut too much. After they all lined up in the bay and to the intercooler and turbo, I took all the pieces that are at my feet to a local muffler shop and told them to weld the pieces together. Since they had numbers and tick marks or where to weld they got it done in under an hour for $35. I use regular silicone and regular worm clamps (89 cents each) and never had anything blow off at 10 psi. Looks intimidating to do, but it's very cheap and custom too.
With the welding done. PS the DP is on the very left hand side, which was done in the same manner only it was 3" piping and cost me $30 in piping .
Old Nov 17, 2004 | 01:25 PM
RyanEJ8's Avatar
Default Re: Please help DIY intercooler piping on integra (adseguy)
^That's the same piping I used.
Old Nov 17, 2004 | 01:33 PM
Ti3d in's Avatar
Curious to know what you piping you used for the DP?
For DIY
Old Nov 17, 2004 | 02:10 PM
RyanEJ8's Avatar
Default Re: Please help DIY intercooler piping on integra (Ti3d in)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ti3d in &raquo;</TD></TR><TR><TD CLASS="quote">Curious to know what you piping you used for the DP?
For DIY </TD></TR></TABLE>
I didn't do a DIY downpipe. Lovefab made my dp.
Old Nov 17, 2004 | 02:20 PM
Ti3d in's Avatar
Oh sorry I was talking to adseguy.
Old Nov 17, 2004 | 03:45 PM
RyanEJ8's Avatar
Here is the link I promised.
Old Nov 17, 2004 | 03:46 PM
RyanEJ8's Avatar
Oh ok. I thought you were talking to me because you had my name in your title.
Old Nov 17, 2004 | 03:49 PM
Calvinator's Avatar
are 92-95 civic and 94-01 integra charge pipe routing the same?
Old Nov 17, 2004 | 03:51 PM
B18C1CYA's Avatar
Default Re: Please help DIY intercooler piping on integra (itr206)
nice piping pete
Old Nov 17, 2004 | 04:40 PM
adseguy's Avatar
I used ktellers 3" mild steel 180 ubend. I also bought about 6 feet of straight pipe and a 90 degree bend to do my own custom exhaust out the side of the car. Very cool! If you want pics I'll take some. For the DP I just guesstimated and cut ..then cut maybe once more to really get a good fit. Very easy and cost me a total of $50 with o2 bung and welding time. Cheap and I knew it would fit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xtremeazian &raquo;</TD></TR><TR><TD CLASS="quote">are 92-95 civic and 94-01 integra charge pipe routing the same?</TD></TR></TABLE>
Not really. The thing is each intercooler is in a different position and because manifolds are different and turbo sizes are different It's hard to find Ic piping unless its from a kit. DIY for IC piping is easier then you think. I opened my hood and just took a rough estimate of how I would do it and calculated how many 180's I would need. I ended up with a 90 degree bend and like 12" unused.
Old Nov 17, 2004 | 08:38 PM
TurboCoop's Avatar
I did my own intercooler pipng after getting an estimate for $1200 (Im not kidding either) for the intercooler piping, downpipe and 3" exhaust at a local shop. I went searching and found the same link thats already posted in this thread and did all the cutting and fitting myself, I even used a hacksaw because I didn't have a sawzall. It was easy as hell and the pipes only cost me like $60 from JC whitney, and I got them welded cheap. I ground the welds smooth and painted the pipes with high temp aluminum colored paint. So that is a very good link with step by step instuctions that worked perfectly for me.
These first pics are with my old SSautochrome shitty manifold, and 2.25" DP setup. Now, in the last pic, I have a new log manifold, 3" DP, and a custom wastegate dump out of the front bumper, but I still have my good old homemade intercooler pipes
Old Nov 17, 2004 | 09:15 PM
godrifttoday's Avatar
itr206 your intercooler pipe does not seem so good (not in welding) but their is to many turns which equals less hp
Old Nov 17, 2004 | 11:09 PM
B18C1CYA's Avatar
Default Re: Please help DIY intercooler piping on integra (godrifttoday)
well look at his sig he had no problems making great power
Old Nov 18, 2004 | 04:06 AM
trust me dude, i had no probs with HP. everything was gradual bends, nothing tight or harsh. plus i never blew off pipes like %90 of the people here.
Old Nov 18, 2004 | 10:06 AM
more diy piping please .Thinking to just get 3 180 u bend will it be alright i can cut into halfto get 90 bend right?
Old Nov 18, 2004 | 10:18 AM
all my piping was 3-180's and 3-90's. and i had quite a bit left over
Old Nov 18, 2004 | 12:32 PM
cool i just think u should try to make it straiter
Old Nov 18, 2004 | 12:53 PM
again why? Does it look like i had any probs making power?
Why do you think it should be straighter? Have you tested flow differences or just ASSuming that it doesnt flow well because of the bends. They arent hard bends like everyone elses. They are more gradual , therefor actually flowing easier.
Old Nov 18, 2004 | 12:57 PM
B18C1CYA's Avatar
pete i like your piping so much iam going to copy the after i/c pipe for my new setup , and there are no many more bends in your pipe than my drag kit had.
Old Nov 18, 2004 | 02:20 PM
Default Re: Please help DIY intercooler piping on integra (B18C1CYA)
we copyrighted that **** sucka. you gotta pay to use our design. lol
Old Nov 18, 2004 | 02:47 PM
nate951's Avatar
Default Re: Please help DIY intercooler piping on integra (tilt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tilt &raquo;</TD></TR><TR><TD CLASS="quote">http://www.cse.uconn.edu/~yele....html</TD></TR></TABLE>
who's page is that? I noticed it was a UConn URL, I am at UConn...
