Pistons, Rods, ....
Old Dec 1, 2004 | 08:31 AM
Gsr94black's Avatar
Default Pistons, Rods, ....
I was wondering what people suggest piston and rod wise when im going to run a sc34 turbo. My goal is to get in the 300hp range. I just need some good parts at the same time not parts that will break my wallet. Also where could i get some intercooler pipping if im running a log manifold, jonnyracecar intercooler, and the sc34 turbo? Also, will DSM injectors work with that setup?
Old Dec 1, 2004 | 08:35 AM
IntegracinGSR's Avatar
Default Re: Pistons, Rods, .... (Gsr94black)
If 300 is your goal.. eagle rods will be fine and CP pistons are always a good choice for any HP level, prolly not the cheapest though.. Not sure about the IC piping.. and i would go a lil larger than the DSM 450s if you're goin into the 300 whp level.. hope that helps..
Old Dec 1, 2004 | 08:39 AM
Revhard has aluminum charge pipes but as for the rest you'll have to look around
Old Dec 1, 2004 | 08:42 AM
Aggressive Racing's Avatar
if your only looking to make around 300 why not leave it stock,spend the money on an ecu,injectors and head studs.If tuned correctly you can make 300 to 350 to the wheels and it will still be reliable.
unless your planning to up the anti in the future.
Old Dec 1, 2004 | 08:46 AM
PM-Performance's Avatar
it would be nice to know what engine. 300whp can be done on a stock DOHC Vtec motor, but not as easy on an LS, but deff not nearly close to easy yet possibly impossible on a stock Single cam.
Makes a big diff dude. Elaborate more.
Old Dec 1, 2004 | 09:05 AM
Default Re: Pistons, Rods, .... (itr206)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">it would be nice to know what engine. 300whp can be done on a stock DOHC Vtec motor, but not as easy on an LS, but deff not nearly close to easy yet possibly impossible on a stock Single cam.
Makes a big diff dude. Elaborate more. </TD></TR></TABLE>
dude what are you talking about,its obvious he has a gsr motor,and i dont know about you but i make easilly over 300 to the wheels on a stock gsr motor with a turbo kit,nobody is talking about no single cam!!!!
Old Dec 1, 2004 | 09:10 AM
Default Re: Pistons, Rods, .... (aggressivemotorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aggressivemotorsports &raquo;</TD></TR><TR><TD CLASS="quote">
dude what are you talking about,its obvious he has a gsr motor,and i dont know about you but i make easilly over 300 to the wheels on a stock gsr motor with a turbo kit,nobody is talking about no single cam!!!!</TD></TR></TABLE>
Relax I didnt look at his name and put 2+2 together.
I know you can make more than 300whp on that motor.Hence if you read my post I said that. I have personally done it too so i know from experience.
Old Dec 1, 2004 | 09:11 AM
Cool
m R g S r's Avatar
No! My sn is mrgsr, i do have a milano red gsr, but i dont have a gsr motor, bitch!
Old Dec 1, 2004 | 09:15 AM
Default Re: Pistons, Rods, .... (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">
No! My sn is mrgsr, i do have a milano red gsr, but i dont have a gsr motor, bitch!</TD></TR></TABLE>
I dont understand where you even fit into this post the orignal poster was 94gsrblack, and as for bitch,be a little more grown about the situation.
no one likes on online bully
Old Dec 1, 2004 | 09:19 AM
lanojp1's Avatar
contact project DC2 from spoolin performance, he will hook you up with some pimp *** IC piping...
Old Dec 1, 2004 | 10:10 AM
Will edit assuming he was talking to someone else. Sorry
Old Dec 1, 2004 | 10:13 AM
FOrSfEd's Avatar
Pete I think he might have been talking to mRgsr
Old Dec 1, 2004 | 10:30 AM
Default Re: Pistons, Rods, .... (FOrSfEd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FOrSfEd &raquo;</TD></TR><TR><TD CLASS="quote">Pete I think he might have been talking to mRgsr</TD></TR></TABLE>
Old Dec 1, 2004 | 10:36 AM
sorry dude.
Old Dec 1, 2004 | 07:33 PM
Gsr94black's Avatar
Well i was going to run 9:1 compression with this setup just for safety reasons or is that too low...im not sure what the future will hold though...i may boost more. But i also drive the car everyday and i don't want it to sacrifice driveability since i drive down a road with alot of stop lights and some highway. Any suggestions on that?
Old Dec 1, 2004 | 08:39 PM
PrettyLude's Avatar
9 : 1 will be fine, alot of tuners i talk to would only suggest no higher than 9 :1 for the streets
Old Dec 1, 2004 | 10:23 PM
If your goal is only 300whp keep the 10:1 CR and u can still run pump gas.. if you plan to push a lot more power later, say in the area of 400 and up than i'd lower it to 9:1 just so u have no problem running pump gas..
And before everyone starts flaming, i know plenty of people have made 400+ or 500+ on pump gas, but when you start goin up that high, its pushin the limits of pump gas without detonation..
montanacivic
Dec 29, 2018 04:16 AM
Miracle11
Jul 27, 2010 09:35 PM
jamartin0519
Jan 13, 2005 10:56 PM
LouisM
Feb 19, 2003 06:52 PM
