Piston to valve clearance?.. Dumb question :/
hey.. when i did my head gasket, i forgot to line it up at #1 TDC before i pulled the Tbelt/head.
So, when i bolted the cams back in (bolted them in so that valves open were with pistons that were down) the timing was off.
Now.. I turned the crank as i turned the cams.. (yeah a bit of each one each time) and got everything lined up... (so i thought)
intake came was 180deg out.. But exhaust was on the money.
I turned the intake cam slowly with my hand, and it turned real easy. Now its a gsr block/ctr head.. So pistons arent domed, and im running a 0.072" headgasket.. almost twice stock.
Now.. i hightly doubt id beable to bend the valves by turning the camshaft with my hand.. Right?
Hmm..
to me for not setting it when i pulled it.
Hmm..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coneheadsracing »</TD></TR><TR><TD CLASS="quote">your fine, good luck bending a valve turning your cam by hand
thanks.. that what i figured, but im over pariond about ANYTHING inside the motor.
</TD></TR></TABLE>thanks.. that what i figured, but im over pariond about ANYTHING inside the motor.
AllMotor12s
32
Aug 15, 2007 03:25 PM
Irishweird00
May 22, 2004 08:26 AM
