Piston Compression ratio question...GSR to LS--->
Old May 11, 2004 | 05:56 PM
jonnybravo's Avatar
Default Piston Compression ratio question...GSR to LS--->
If a piston for an LS is 10.5:1 with a stock head, what will it be in a GSR?
Old May 11, 2004 | 07:14 PM
Derek14's Avatar
Default Re: Piston Compression ratio question...GSR to LS---> (jonnybravo)
well in a type r C5 motor, it would be about 10.7 or so... add .2 to that, and you've got about 10.9-11 CR in a GSR if im not mistaken...
Old May 11, 2004 | 07:55 PM
jonnybravo's Avatar
Default Re: Piston Compression ratio question...GSR to LS---> (Derek14)
So the compression ratio will definitely be higher though right?
Old May 11, 2004 | 09:19 PM
saleensolution's Avatar
it should be but also if you do that remember the valve releifes are bigger in the intake side of the gsr so you may want to fly cut the piston
JFG Kevin
Nov 19, 2006 10:50 PM
0bd1_Kanobe
Mar 19, 2004 01:30 PM
4doorH22
Sep 7, 2001 08:29 AM
