Pics: JRSC rebuild
Old Sep 21, 2003 | 10:18 AM
Andre's Avatar
Default Pics: JRSC rebuild
This is how the JRSC looked when i received them from HoustonSi:
And this is how it looks now:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Charger was checked out to every last mm on the roters at the time of engine build (Jan 03)</TD></TR></TABLE>
Should i have them recoated?
Thanks for looking, Andre
Old Sep 21, 2003 | 10:39 AM
PreIudeSI's Avatar
From: California ... Beauuutiful, so cal, pwnited States
Default Re: Pics: JRSC rebuild (Andre)
nice work... shouldn't there be teflon coating on the rotors?
Old Sep 21, 2003 | 10:42 AM
3RdT's Avatar
Default Re: Pics: JRSC rebuild (PreIudeSI)
nice
Old Sep 21, 2003 | 10:44 AM
Andre's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PreIudeSI &raquo;</TD></TR><TR><TD CLASS="quote">nice work... shouldn't there be teflon coating on the rotors?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Should i have them recoated?</TD></TR></TABLE>
Old Sep 21, 2003 | 10:47 AM
Andre's Avatar
Default Re: Pics: JRSC rebuild (3RdT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3RdT &raquo;</TD></TR><TR><TD CLASS="quote">nice </TD></TR></TABLE>
Thanks, but it's not finished yet. The inside of the housing is like a mirror now and all other parts will be polished. All bearings, seals and gaskets will be replaced.
Old Sep 21, 2003 | 12:50 PM
Dyno Queen's Avatar
Sand blasting your *** off!!!! good job
Old Sep 21, 2003 | 01:47 PM
thrty8street's Avatar
did you do this yourself or did you have it done?
Old Sep 21, 2003 | 01:59 PM
Andre's Avatar
Default Re: (thrty8street)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thrty8street &raquo;</TD></TR><TR><TD CLASS="quote">did you do this yourself or did you have it done?</TD></TR></TABLE>
All the work is done by a friend and myself.
Old Sep 21, 2003 | 09:06 PM
lol at u's Avatar
Default Re: (Andre)
how hard is the rebuild? and how much is it costing you?
Old Sep 21, 2003 | 09:17 PM
keebler65's Avatar
Default Re: (b20 DA9)
looks great. it looks horrible how it was painted from what i've heard, the teflon coating is very beneficial to the blower.
Old Sep 21, 2003 | 09:19 PM
v-attack's Avatar
From: First in Flight, Type Rs of East Coast, NC, FL
Looks good.
Old Sep 21, 2003 | 10:18 PM
sporkcrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20 DA9 &raquo;</TD></TR><TR><TD CLASS="quote">how hard is the rebuild? and how much is it costing you?</TD></TR></TABLE>
Also, where are you buying all of the gaskets etc.?
Old Sep 22, 2003 | 02:21 AM
Andre's Avatar
It is not realy difficult, but a lot of work. The rotors takes 3 hours with a Scotch Brite.
The problem is that you can't take off a lot of material, we only take off about or less than 0.1 mm from the housing and the rotors, so everything should be inside the tolerances.
Glass or sand blasting is also not the best idea, you get tiny dents in the surface, so we used "plastic *****".
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx &raquo;</TD></TR><TR><TD CLASS="quote">Also, where are you buying all of the gaskets etc.?</TD></TR></TABLE>
I will make them from gasket sheets.
Btw: There were no gaskets between the SC parts when i received them.
Old Sep 22, 2003 | 04:44 AM
Andre's Avatar
Default Re: (keebler65)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keebler65 &raquo;</TD></TR><TR><TD CLASS="quote">looks great. it looks horrible how it was painted </TD></TR></TABLE>
Old Sep 22, 2003 | 04:48 AM
GreddySi99's Avatar
Default Re: (Andre)
god it looks a million times bette rthan it did before. since that is a 3rd gen blower I would definetly recoat the rotors. the reason for that is right now the clearance is huge and the blower will be less efficient at lower boost levels. when it is coated the clearance will be tighter and the blower will be more efficient.
Old Sep 22, 2003 | 06:03 AM
Blue-Civic-Hybrid's Avatar
Loved
Default Re: (Andre)
I think I'll just take the easy way out and send my S/C to either Endyn or Jackson for the rebuild...this looks like there are too many areas to screw up in when you are sanding down the rotors...
Old Sep 22, 2003 | 08:09 AM
GreddySi99's Avatar
Default Re: (Blue-Civic-Hybrid)
if you send your SC to endyn your a idiot. nothing they can do to your blower will offset the money they charge you. ask around and you will find out the easy way
Old Sep 22, 2003 | 08:14 AM
T4eg's Avatar
good post
Old Sep 22, 2003 | 06:08 PM
Loved
Default Re: (intercooledJRSC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by intercooledJRSC &raquo;</TD></TR><TR><TD CLASS="quote">if you send your SC to endyn your a idiot. nothing they can do to your blower will offset the money they charge you. ask around and you will find out the easy way</TD></TR></TABLE>
I've seen the work they do, and they charge about the same as Jackson racing does for rebuild, so why am i an idiot? Have you ever seen an Endyn head or anything they have done?
Type-Spaz
Apr 8, 2012 11:03 AM
FOUR-G
Oct 24, 2006 06:10 PM
spoonef
Jul 11, 2006 02:33 PM
BringIT
Apr 12, 2004 02:34 PM
RyanAutry
Mar 24, 2003 04:09 PM
