Pics Of breather Kit setups
Hey, I'm looking for some pics of breather kit setups. I'm wanting to run 4 -12an's out of the valve cover. Has anyone ran something that big out of the back of the valve cover. I was going to run 90 degrees out the back but unless I put them on like a 30 degree angle up I don't think it's going to work. Any pics of someone that has ran them out of the back on the valve cover? Any opinions?
first off search theres a whole thread with over 15 pages covering this subject also whats your power level and are you running two lines for the block and then another two lines for the head also why -12AN
I know I've seen a couple of setups and I did search and couldn't come up with anything. Going for 800+hp. I'm going to try something new and not do the two off the back of the block. We've tried a couple of those setups and the oil just always seems to go back up the return line. So I was just gonna do the 4 off the valve cover and hope it does the job. If not we're move on from there. And the -12an's because the moroso cans have a -12an fitting on them, so I'm welding another -12an bung on the can.
I'm curious if anyone has ran 2 -12an 90's from the back on the valve cover, to the driver side of the engine bay, around the IM to the firewall. I noticed Tony is taking 2 -10an's straight off the back of the VC. Which isn't a bad idea... But I don't really want to go over the VC. Help me out.
migs
22
Mar 26, 2008 05:23 PM
