Oversized valve clearance.....????
Old Jun 1, 2007 | 11:38 PM
ProjectBoosted's Avatar
Default Oversized valve clearance.....????
I am running .5mm oversized flattop valves in my PnP'd B16a2 head, it has aftermarket valve springs and retainers in it with itr cams. I am runnning a stock B16a2 block. with the dome on the stock b16a2 pistons will i have a clearance problem with the oversized valves?
Old Jun 2, 2007 | 03:05 AM
DaveF's Avatar
Default Re: Oversized valve clearance.....???? (ProjectBoosted)
valve to piston ?
Old Jun 2, 2007 | 02:58 PM
Default Re: Oversized valve clearance.....???? (dturbocivic)
yes valve to piston? i don't want to start it up and bend the valves
Old Jun 2, 2007 | 03:10 PM
doood's Avatar
been there done that
clay the engine before initial startup and check your clearances
Old Jun 2, 2007 | 06:37 PM
RC000E's Avatar
Default Re: Oversized valve clearance.....???? (doood)
Man, if your asking Honda Tech members to tell you if your internal clearances are good or not....I'm gonna say your in for some problems.
The valve reliefs are cut into the piston for stock diameter valves....do they have extra? Only way to know is to clay it man...do it the right way. If you do, then the day you start that motor up, you KNOW it's good. Don't forget to manually engage vtec when you clay it
EH3forlife
12
Jan 20, 2008 07:55 PM
hu
Jul 12, 2006 10:08 AM
lyckaon
Nov 20, 2005 11:05 PM
Tad
20
Aug 26, 2004 04:31 PM
KStuned
Feb 26, 2002 01:42 PM
