Overheating Problem w/ hot weather
Old Mar 9, 2009 | 01:37 PM
inthad's Avatar
Default Overheating Problem w/ hot weather
I have 99 si b16a2 turbo overheating when i turn on the a/c.
It never overheat in when i don't turn it on.
But its getting hot now and i turn it on it over heats.. ...
i have slim fan 10" on both the radiator and a/c condensor.
Anybody have this problem?
Old Mar 9, 2009 | 01:57 PM
red02s2k's Avatar
Default Re: Overheating Problem w/ hot weather
What rad. are you using? Plus you most likely need a better fan that pulls enough cfm to keep the heat out. There is other things vent the hood, oil cooler and turbo blanket/wrap.
Old Mar 9, 2009 | 03:24 PM
DRAMA's Avatar
May need a bigger/newer radiator. I had a similar problem in my old 91 Integra. Since the engine bay is so cramped with a turbo, things really heated up in there.
Old Mar 9, 2009 | 04:48 PM
inthad's Avatar
I need bigger/newer radiator?
What kind is best?
What is the cheapest radiator out there? (prefer)
Old Mar 9, 2009 | 06:51 PM
SI_frankenstein's Avatar
The Mishimoto's are good, Koyo's are good but they are a bit high, Fluidyne radiators are good also but are a bit pricey.
Old Mar 9, 2009 | 07:23 PM
batboyvaj's Avatar
your real problem is with your slim fan. you NEED a shrouded fan.
Old Mar 10, 2009 | 03:44 AM
inthad's Avatar
Shrouded fan? whats that?
explain please
Old Mar 10, 2009 | 04:03 AM
ReDemoN's Avatar
DixielandImports Please
Factory style fan shroud is what he means
Old Mar 10, 2009 | 09:37 AM
inthad's Avatar
so i need a stock a/c fan? i can't use this slim fan.
that defeats the purpose of a slim fan
Old Mar 10, 2009 | 03:12 PM
sp00led's Avatar
Is it that time of year already? I figured I wouldn't see these threads for a few more months.
SPAL fan, make a shroud if possible. Most of honda-tech should agree.
/thread
cilvia
Apr 26, 2008 06:20 AM
TomIntegraGSR
Jun 10, 2007 06:23 PM
aznryd3r
Apr 27, 2006 01:45 PM
J-Brooks
May 21, 2004 06:43 PM
