OK to drive boosted with no fuel management??
I'm going to be boosting pretty soon and I was wondering if it would be OK to drive it about 60+ miles with DSM 450cc Injectors and a Walbro 255lph Fuel Pump without any sort of tuning whatsoever. The reason is because after boosting, I plan to drive the car about 60 miles to a shop to get it tuned with Hondata and was wondering if I'd be able to make it.
not a good idea man!! You will barely be able to idle those 450cc and they will be dumping mad fuel..what engine management do you intend on running?
Screw you guys, I'm... going... home.
Drive it over there on your stock injectors with your wastegate tied open or you might not make it. Your choice though.
Think about this, with 450cc injectors and nothing to control it? Like giving a cocky stang driver a Viper, nothing will control him.
Stay with stock injectors, and swap them when ur at the shop like what the above people said
It should also be possible to drick with the stock injectors and normal wastegate.
But you have to keep the car so that you don't build boost. Its possible if you can control your right food ;-)
i boost gauge will help... you are not fast but it should be safe if you keep everything slow.
Greets
Malte.
Greets
Malte.
well if you are going to buy/get hondata, then call the shop and have them send u a basemap so u can at least drive it over there to get it FINE tuned
just drive over there with stock injectors and dont smash the gas. if your dont floor it you wont boost.. it's that simple..drive normal.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Toda Party »</TD></TR><TR><TD CLASS="quote">well if you are going to buy/get hondata, then call the shop and have them send u a basemap so u can at least drive it over there to get it FINE tuned
I already have Hondata S200B but it's not installed. Excuse my noobness, but when you say to get a basemap.. do you mean have them send me one thru email or something and I have to program it onto my Hondata somehow? If that's the case, I have no clue how to do that stuff.
So it would be okay to drive there with stock injectors and the Walbro 255lph (non-High Pressure) Fuel Pump?
Also, would it be okay to drive there with the resistor box for the 450cc injectors installed with stock injectors? I wanna get as much done as possible before taking it to the tuner so I don't get charged up the *** for other simple installs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quad-Damge »</TD></TR><TR><TD CLASS="quote">drive there with nothing on your charge pipes to the tb, diconnect it, it will be hella slow, u will be ok</TD></TR></TABLE>
dont do this. It's a bad idea to disconnect the charge pipe as it might make the turbo overspin. just leave it connected and drive slow.
put in your stock injectors and take off your wastegate...thats what i did when i drove like 10 miles to get my car tuned...only problem would be heatbuild up from the exhaust gases, but idk, its a lot better than a blown motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattcalica »</TD></TR><TR><TD CLASS="quote">put in your stock injectors and take off your wastegate...thats what i did when i drove like 10 miles to get my car tuned...only problem would be heatbuild up from the exhaust gases, but idk, its a lot better than a blown motor.</TD></TR></TABLE>
so you suggest he drive for the 60 miles without a wastegate and have exhuast gases just shooting out his manifold???
do u realize how hot those gases are? leave it all connected and just dont boost. just have the stock injector and no resistor box. the fuel pump is ok.
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM Ninja »</TD></TR><TR><TD CLASS="quote">I'm going to be boosting pretty soon and I was wondering if it would be OK to drive it about 60+ miles with DSM 450cc Injectors and a Walbro 255lph Fuel Pump without any sort of tuning whatsoever. The reason is because after boosting, I plan to drive the car about 60 miles to a shop to get it tuned with Hondata and was wondering if I'd be able to make it.</TD></TR></TABLE>
That's like asking if you should bang Jenna Jameson without a condom.
Don't risk it, just get some fuel management first, then go to the dyno and tune.
Sort of a related topic, if you have a VAFC, cant you just lean the **** out of your car to compensate for the 450cc injectors? Like, is it safe?
dont mean to hijack, but the thought just like popped in
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head »</TD></TR><TR><TD CLASS="quote">stock injector, stock pump, unhook the chargepipe.
seriously, have it towed to the shop already</TD></TR></TABLE>
Tow it, I'm guessing your trying to save some $$ by doing the simple work yourself?
Call the shop and see if they have any friends in the towing biz (they almost always do), they may have a deal worked out with one company and the tow dude may cut your rate to go to the shop.
That's not the reason why I made it. I made this thread because I didn't know whether or not it was safe to drive like that. Anyways.. I'm just going to drive there with stock injectors, stock pump, with charge pipe disconnected; so the car would be pretty much like stock.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo E 604 »</TD></TR><TR><TD CLASS="quote">i think the reason anyone makes these threads is that they hope someone will say," yah, it'll work, you can do it" even tho they know they really shouldn't.</TD></TR></TABLE>
aint that the truth...lol and u know u'll get 90 posts saying u CANT and u get one that says u CAN and so u go for it anyway...
