OIL SQUITER TORQUE SPECS B16
Old Jun 5, 2004 | 10:50 AM
CRX T-Si's Avatar
Default OIL SQUITER TORQUE SPECS B16
I already searched but could not find the torque specs for the oil squiters for the b16.
Also are there suppose to be aluminum or copper washers there???? Machine shop took them off to do the overbore. I took them off to clean them but don't have the torque spec.
let me know. thanks guys/gals
Old Jun 5, 2004 | 11:12 AM
B18EG6's Avatar
Default Re: OIL SQUITER TORQUE SPECS B16 (CRX T-Si)
b18c motor is 12 lb/ft for the squirters
Old Jun 5, 2004 | 11:17 AM
m R g S r's Avatar
Default Re: OIL SQUITER TORQUE SPECS B16 (B18EG6)
Unless you have a very good torque wrench, I wouldn't try and torque the to 12ft/lbs. I used loctite on mine and hand tightened them with a T-handle. You risk snapping the bolts if the torque wrench isn't dead on.
Old Jun 5, 2004 | 11:52 AM
CRX T-Si's Avatar
Default Re: OIL SQUITER TORQUE SPECS B16 (m R g S r)
What about the other question??? does it have aluminum or copper washers???
Old Jun 5, 2004 | 12:09 PM
m R g S r's Avatar
let me go check....
It doesn't look like it, so I'm going to say no.
BIG T
Jul 3, 2015 10:30 AM
Suzukii
Dec 1, 2006 06:34 PM
m00nr0ck Si
Jan 1, 2006 11:39 AM
