Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Forced Induction (https://honda-tech.com/forums/forced-induction-16/)
-   -   oil on spark plug... (https://honda-tech.com/forums/forced-induction-16/oil-spark-plug-60273/)
KekeK-18 Aug 15, 2001 03:43 PM
I found some oil on the tread of the plug(cylinder1)... no smoke though. It only occurs in cylinder 1. Did a compression test and the result are good 230, 225, 230, 230. I chaged the valve cover gasket and the 4 rubber spark plug gaskets and still no cigar. Any thought?? when I chage it with a new plug I see it start from the base of the plug...then to the tread and to the tip... Any thoughts or suggestion.
As a matter of fact, I switch to synthetic oil (mobil1 10w30) a month ago...could it be the oil???
Suprdave Aug 15, 2001 04:30 PM
Re: oil on spark plug... (b18cturbo)
I'm seeing the same thing...My cars not even running yet...
Ill hafta see the CR\Leakdown numbers...
Dave
KekeK-18 Aug 15, 2001 04:41 PM
Re: oil on spark plug... (Suprdave)
My cars been running strong with out smoke or any other problems...Its just the oil on plug #1 that bothers me....
Come on ppls, someone must know something....
dustin Aug 15, 2001 05:16 PM
My plugs always have oil on the threads... but I am sure mine is from the valve cover leaking. Are you sure it is not leaking still?
Oil on the threads is almost always caused by a leak above the plugs.
Dustin
