Oil return/ Leaky hot side/ need some suggestions........
Sup guys,
Need a lil help with this oil return. It looks like i shouldnt be having any drain issues but im noticing a lil bit of oil collecting on the bottom of the hotside. You can see from the pic its not a lot of oil but its definitely there. Background is a fresh build, just installed kit and the turbo hasnt seen boost yet. PCV system was replaced with a catch can venting from the valve cover and oem port next to the oil filter. I also am venting from one of the ports from the oem breather. I still dont know how extensive this is since i havent yet been able to run the car through its paces. I just recently installed a 45 and routed the line around the charge pipe. The problem im running into is that the moroso pan return setup is kinda in the way of my charge piping (peakboost kit). Again this setup has about 20miles on it without boosting. Check out the pics and lemme know!! https://honda-tech.com/forums/images/smilies/emthup.gif I ran these pics in a series to show how the line flows. The last two pics show the other side of the charge pipe. https://i48.photobucket.com/albums/f...oogsr/oil1.jpg https://i48.photobucket.com/albums/f...oogsr/oil2.jpg https://i48.photobucket.com/albums/f...oogsr/oil3.jpg https://i48.photobucket.com/albums/f...oogsr/oil4.jpg https://i48.photobucket.com/albums/f...oogsr/oil7.jpg https://i48.photobucket.com/albums/f...oogsr/oil8.jpg Is this slight bend causing the backup even though its still on a decline? |
Sorry for the POV, it definitely makes it hard to get the alignment.........
uppp....... need some advice, she goes for a tune on the 1st!
Re: (slooogsr)
Hard to tell by pics but it looks OK to me.
Re: (MooreBoost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MooreBoost »</TD></TR><TR><TD CLASS="quote">Hard to tell by pics but it looks OK to me.</TD></TR></TABLE>
Awesome....... i thought the same but im still unsure why its leaking a tiny bit. I may just run with it until after the tune and check things out after i have some miles on it. |
How big is your feed?
same things happening to me...it's fine your turbo will be fine just sucks having oil drip where you park lol. hey i go for a tune on the second.
Re: (inspyral)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral »</TD></TR><TR><TD CLASS="quote">How big is your feed?</TD></TR></TABLE>
Yeah are you running an oil restrictor?? I had the same problem one time and bought an oil restrictor from ATPTurbo.com and it doesn't do it anymore. I have heard that all honda's need an oil restrictor due to their high oil pressures but I'm not sure if thats true but I will be using them on all my future setups. Thats what I would do if I was in your position. |
Re: Oil return/ Leaky hot side/ need some suggestions........ (slooogsr)
Your return looks fine from what I can see, it's probably the feed. I would not just run it like that though.
Re: (inspyral)
The feed is a -3, comes with the peakboost kit. Should i use an oil restrictor? Ive heard conflicting advice on this subject, it would be nice to figure it out once and for all........ <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White Smoke »</TD></TR><TR><TD CLASS="quote">Your return looks fine from what I can see, it's probably the feed. I would not just run it like that though. </TD></TR></TABLE> Awesome thanx, ill look into the feed problem then. |
Re: (slooogsr)
Yes you should use a restrictor! Contact Stan @ fast-turbo, he was having some -3an restrictors made.
Re: (White Smoke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White Smoke »</TD></TR><TR><TD CLASS="quote">Yes you should use a restrictor! Contact Stan @ fast-turbo, he was having some -3an restrictors made.</TD></TR></TABLE>
https://honda-tech.com/forums/images/smilies/emthup.gif Def. |
Re: (delslo93)
The return looks fine.
And it's pretty normal for your turbo to seep a bit like that. As long as it's not totally wet under there I'd say you are fine. |
Sweet thanx for the responses guys, i decided to run a restrictor and ordered one from ATPturbo like someone did above. Freakin things are expensive as hell......... wish i could have made one.
Re: (EJ1 wilcox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox »</TD></TR><TR><TD CLASS="quote">The return looks fine.
And it's pretty normal for your turbo to seep a bit like that. As long as it's not totally wet under there I'd say you are fine. </TD></TR></TABLE> Yea its just seeping a lil bit, but i still dont have enough miles on it to gauge exactly how much. Oil pressure is upwards of 80psi when its cold and warming up so i figured i should just run a restrictor just in case. Does a turbo have a break in period? I hear the seals on them are more like piston ring seals........ |
Re: (slooogsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slooogsr »</TD></TR><TR><TD CLASS="quote">Sweet thanx for the responses guys, i decided to run a restrictor and ordered one from ATPturbo like someone did above. Freakin things are expensive as hell......... wish i could have made one.
</TD></TR></TABLE> I thought ATP only had -4 ones??? Stan's were supposed to be pretty cheap. Cheaper then ATP anyway. Did you try to contact him??? |
Re: (slooogsr)
Does a turbo have a break in period? I hear the seals on them are more like piston ring seals........ </TD></TR></TABLE> I don't know about a break in period, I don't think so... but you are right on the turbine seal. It's a ring that looks similar to a thick piston ring. |
Re: (White Smoke)
I thought ATP only had -4 ones??? Stan's were supposed to be pretty cheap. Cheaper then ATP anyway. Did you try to contact him???</TD></TR></TABLE> Shit, i didnt freakin look at that........... http://www.atpturbo.com/Mercha...e=OIL This is what i ordered, it says it will screw right into t3/t4's etc..... I think it will be fine since my current feed line fitting screws right into the center cartridge as well. |
Re: (White Smoke)
I thought ATP only had -4 ones??? Stan's were supposed to be pretty cheap. Cheaper then ATP anyway. Did you try to contact him???</TD></TR></TABLE> No i ordered from atp before you even suggested Stan........ dunno why i didnt even think of contacting him....... https://honda-tech.com/forums/images/smilies/emsad.gif |
Re: (slooogsr)
I got a restrictor from mcmaster for cheap! What turbo are you running?
Re: (B18EG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18EG6 »</TD></TR><TR><TD CLASS="quote">I got a restrictor from mcmaster for cheap! What turbo are you running?</TD></TR></TABLE>
T3/T4......... i already ordered one, i didnt even know mcmaster carried them either! Fittings cost too damn much online.......... |
Re: (slooogsr)
can anyone confirm that the restrictors are good or bad? https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images...s/emthdown.gif
Re: (TURBODC4TEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TURBODC4TEG »</TD></TR><TR><TD CLASS="quote">can anyone confirm that the restrictors are good or bad? https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images...s/emthdown.gif </TD></TR></TABLE>
They are good. Everyone I know runs one. Do some searching on oil restrictor and you will find that most people run them. https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: (EJ1 wilcox)
They are good. Everyone I know runs one. Do some searching on oil restrictor and you will find that most people run them. https://honda-tech.com/forums/images/smilies/emthup.gif </TD></TR></TABLE> thanks, is it cheaper from atp or stan? |
Re: (TURBODC4TEG)
thanks, is it cheaper from atp or stan?</TD></TR></TABLE> Id go with Stan, he wont rape you on shipping like atp.......... http://images.honda-tech.com/set1//smile/emcrook.gif |
