Oil Pressure
Old Dec 19, 2005 | 05:49 PM
_gurusan_'s Avatar
Default Oil Pressure
Curious if I am going to have to worry about any oil pressure problems with my oil setup?
I have a remote oil filter kit and my lines go like so :
-remote oil filter block adapter-->T--one side is turbo feed, other side goes to remote oil filter
Just wondering if teeing off the filter supply line will cause any pressure problems?
Here's a crappy pic
Old Dec 19, 2005 | 05:54 PM
TEG777's Avatar
Default Re: Oil Pressure (_gurusan_)
The oil pressure should be fine, i wouldny have that tee hanging off the block like that, it could break
Old Dec 19, 2005 | 05:55 PM
Boilermaker1's Avatar
I'd Tee off the filter RETURN.
Otherwise you're short circuiting unfiltered oil back through the turbo and into the pan without filtering it. A small quantity, yes, but filtered oil through a turbo sounds like a much better idea. I'm splitting a -4 line off my -10 oil cooler return.
Old Dec 19, 2005 | 06:06 PM
platinum00's Avatar
it depends on what size lines your using.
just get a oil pressure gauge and make sure you in spec...
platinum.
Old Dec 19, 2005 | 06:49 PM
_gurusan_'s Avatar
Default Re: Oil Pressure (platinum00)
Thanks....lines to remote filter are 3/8 and turbo feed lines are -3 an. I will switch the T to the filter return port like the suggestion.
Do you really think it might break off? The brass fittings seem pretty strong.
Old Dec 20, 2005 | 06:28 AM
platinum00's Avatar
it could in theory with the weight of the brass T's, leak a bit, but i dont think it will break off.
the best way is to run a line from the back the block to a T you have mounted somwhere, dont run the T off the block directly.
you will be fine either way though. i ran the T for years of the block with no issues.
platinum.
Old Dec 20, 2005 | 07:05 AM
Muckman's Avatar
Moderator in Chief
What manifold is that?
Old Dec 20, 2005 | 07:58 AM
.dave's Avatar
i HAS questions ?
Default Re: Oil Pressure (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">What manifold is that?</TD></TR></TABLE>
Looks like one of ccfab's manifolds.
Old Dec 20, 2005 | 08:11 AM
_gurusan_'s Avatar
Default Re: Oil Pressure (daveG)
yeah...the infamous rex that is hot made it.
Old Dec 20, 2005 | 08:20 AM
EJ1 wilcox's Avatar
Default Re: (Boilermaker1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boilermaker1 &raquo;</TD></TR><TR><TD CLASS="quote">I'd Tee off the filter RETURN.</TD></TR></TABLE>
Definately.
You want clean oil running through your turbo. The bearings can get damaged if there are even small particles in the oil supply.
And it wouldn't be that hard to switch so I would definately do it if I were you.
Old Dec 20, 2005 | 10:41 AM
_gurusan_'s Avatar
Default Re: (EJ1 wilcox)
definitely will do.
hndacord02
May 30, 2010 07:23 AM
ImPuLsIvE
Jun 14, 2008 05:38 PM
creechrr
Jan 2, 2007 02:04 PM
DavidR
Feb 13, 2006 04:03 PM
9hatch6
17
Apr 24, 2005 04:08 PM
