Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Forced Induction (https://honda-tech.com/forums/forced-induction-16/)
-   -   oil light on... (https://honda-tech.com/forums/forced-induction-16/oil-light-1663861/)
acman1 Jun 18, 2006 04:12 PM
oil light on...
does this always mean low or no oil pressure? its a built gsr turbo. im looking to buy it from someone on the board, but he said the oil light just came on and now it is smoking a little and there was a ticking noise at 2-3k rpm's. when he took it somewhere, the mechanic just said it needed a valve adjustment. should i be worried? any ways to check to see if its an oil pump or the motor is f'ed? let me know if you need anymore info to diagnose the problem.
A.E Motoring Jun 18, 2006 04:13 PM
Re: oil light on... (acman1)
i would pass on it, dont give your self more problems
BoostedEG6 Jun 18, 2006 04:14 PM
if the oil light is coming on and its ticking then I would STAY away from it!!!! unless you want to replace the motor soon https://honda-tech.com/forums/images/smilies/emwink.gif
qfast817 Jun 18, 2006 04:18 PM
Re: oil light on... (BoostedEG6)
yea dont buy
TypeSLO Jun 18, 2006 04:42 PM
Re: oil light on... (qfast817)
why are you even asking?? don't buy!
coneheadsracing Jun 18, 2006 06:03 PM
Re: oil light on... (TypeSLO)
Or......... buy it cheap, thats a good barganing chip, if you are mechanicaly inclined.
Joseph Davis Jun 18, 2006 06:07 PM
Stock Honduh oil pressure switch it a *five* psi switch. If the switch is bad... I've only heard of this happening once, but it is possible... then you could walk with a decent car for pennies if you play it right.
If the oil pressure switch is right, then consider the bottom end and turbo shot, and figure how much it (and the work to fix it) is worth to you then.
