oil leaking from turbo
Old Nov 22, 2002 | 05:56 PM
Jdm_Rice_Monster's Avatar
Default oil leaking from turbo
I have lots of oil coming from my turbo instantly after I start it. I had a clogged return line but I fixed it but there is still lots of oil coming form the exhaust housing side, why would oil be steadily flowing like this. There is no oil in the charge pipes just a stream of oil coming from the center of the turbo, thanks.
Old Nov 22, 2002 | 06:05 PM
ELUD THS's Avatar
New User
Default Re: oil leaking from turbo (JdmRiceMonster)
had the same problem when installing my turbo, if its a turbonetics , it tends to happen. your turbo seals ar going bad. you need a rebuild.
Old Nov 22, 2002 | 06:50 PM
Default Re: oil leaking from turbo (ELUD THS)
Yeah, its a turbonetics exhaust side, garret compressor, if the seal was bad would it leak oil in the pipes because mine doesnt. It just leaks out the middle and some from the downpipe.
Old Nov 22, 2002 | 07:09 PM
boostaholic's Avatar
Check your drain flange. If you don't have a tight seal or didn't use a gasket, oil will find a way to spew out from there and it will get all over the exh. and comp. sides. If you don't have a gasket, atleast line it with some RTV.
Old Nov 22, 2002 | 07:31 PM
Default Re: oil leaking from turbo (boostaholic)
Also when I rev it up, it feels like the power cuts out at like 4k, almost like something is clogged up to where it is restricting everything.
Old Nov 22, 2002 | 08:13 PM
Check your fuel system, could by anything from too much fuel especially if that's when you hit boost to a clogged fuel filter.
Old Nov 22, 2002 | 09:53 PM
H22Prelude's Avatar
Look into a seals kit instead of the whole rebuild kit. The seals kit tends to be a bit less expensive (Mine ran $150 and have a Turbonetics T3/T4). I had a similar problem and now it's all good.
Old Nov 22, 2002 | 10:58 PM
Default Re: oil leaking from turbo (H22Prelude)
Well I havent even got to drive it, its leaking way too much oil to drive, and about those rebuild kits are they a do it yourself type thing, because some place said the could rebiuld my turbo for 300.
Old Nov 23, 2002 | 04:52 AM
civicwagonman's Avatar
anyone else have luck rebuilding your own turbo? i was thinking I could mark the fins so I could line them up again when i'm reassembling them, that way I would'nt have to balance it. i'm puffing blue smoke out the exhaust after a hard boost, and there's oil in the intake of the turbo. I wonder if the turbo is getting too much oil pressure? I am using a 280zx turbo oil line. any way to cut down the oil pressure on the line?
Heylookits shawn
May 22, 2007 06:13 PM
hold your breath
Feb 14, 2007 10:01 AM
tvic
Sep 13, 2005 06:33 PM
InLimbo87
Aug 8, 2004 05:27 PM
echo999
Dec 27, 2001 12:01 PM
