oil feed
ok I'm new to the site and new to forced induction.im setting up my f22b1 for my t3 application. the question is i have my oil return tapped to the oil pan. where is the best spot for the oil feed ? :shrug:
Re: oil feed
You can T it off from the oil pressure sensor with a brass T-fitting, or get an oil filter adapter plate, like one of these: http://www.ebay.com/itm/OIL-FILTER-S...r#ht_500wt_715
Re: oil feed
I prefer using an oil filter adapter, for me it's cleaner and safer. I don't like the idea of running a "T" fitting off the oil pressure sensor. With that said, everyone has their own opinions and styles, this is just mine.
Golden Eagle http://www.goldeneaglemfg.com/index....roducts_id=302 |
Re: oil feed
Thank you guys I ordered the sandwhich adapter should be in wednesday
Re: oil feed
since we are on the subject of sandwich plates you can feed the oil through an oil cooler pre turbo an run an oil pressure/temp gauge as well.... reliability is a nice deal btw what turbo an make sure you run an oil pressure restricter or ya may end up with bad oil seal on the turbine smokey exhaust = doh
| All times are GMT -8. The time now is 02:29 AM. |
