oil in 4th cylinder
Old Nov 28, 2006 | 07:51 AM
gsr2000's Avatar
Default oil in 4th cylinder
As the title states i have oil in my 4tyh cylinder and small amount in the 3rd when i took the spark plug wires off the 4th cylinder the spark plug wire was covered in oil. i still have compression in the cylinders thou, also no over hating problems. When i car has ran for a while smoke from oil burn off come from the exhaust What could cause this?
Old Nov 28, 2006 | 08:44 AM
Honda Sport's Avatar
Default Re: oil in 4th cylinder (gsr2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr2000 &raquo;</TD></TR><TR><TD CLASS="quote">As the title states i have oil in my 4tyh cylinder and small amount in the 3rd when i took the spark plug wires off the 4th cylinder the spark plug wire was covered in oil. i still have compression in the cylinders thou, also no over hating problems. When i car has ran for a while smoke from oil burn off come from the exhaust What could cause this?</TD></TR></TABLE>
no over hating problems huh?? hahahaha...wish we had more of that.
anyways, sounds like you might have a bad spark plug grommet. they usually get old and brittle, cracks form, then leaks oil into the spark plugs. replace those(and valve cover gasket while your at it).
Old Nov 28, 2006 | 09:23 AM
iBrandon's Avatar
Default Re: oil in 4th cylinder (Honda Sport)
valve seals could be leaking as well...
Old Nov 28, 2006 | 10:08 AM
Broken Gearbox's Avatar
people should re-read there post before they post..
"When i car has ran for a while smoke from oil burn off come from the exhaust What could cause this? "
Old Nov 28, 2006 | 10:21 AM
BoostedEG6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda Sport &raquo;</TD></TR><TR><TD CLASS="quote">anyways, sounds like you might have a bad spark plug grommet. they usually get old and brittle, cracks form, then leaks oil into the spark plugs. replace those(and valve cover gasket while your at it).</TD></TR></TABLE>
Thats where I would put my money
Old Nov 28, 2006 | 10:22 AM
Yea if theres oil in the spark plug hole its most likely the grommets underneath the VC.
Old Nov 28, 2006 | 11:41 AM
gsr2000's Avatar
Default Re: (1.8L)
OK thanks, ya i'm not very good with english yet sorry. so just go to acura and they will have what i need? Or is it some thing i have to order?
Old Nov 28, 2006 | 11:42 AM
BoostedEG6's Avatar
Default Re: (gsr2000)
Just go to Acura or Honda or a NAPA and get a valve cover gasket kit it should come with the valve cover gasket and gromlets and everything you need.....
accord2civic2prelude
Mar 11, 2009 07:49 PM
youngvedder
Oct 20, 2006 04:45 AM
civic-8442-
Jul 28, 2006 03:28 AM
93SSPHatch
May 30, 2002 04:27 PM
