OEM head gasket?
Old Jan 23, 2002 | 09:28 PM
InfamousRS's Avatar
Default OEM head gasket?
Im going to replace my head gasket along with all of the other top end gaskets before boosting. Are the OEM gaskets the best choice for a stock motor with 8-10 psi of boost?
[Modified by BLK94RS, 6:29 AM 1/24/2002]
Old Jan 23, 2002 | 09:32 PM
VaporTrail's Avatar
New User
Default Re: OEM head gasket? (BLK94RS)
they are the best choice for just about every level of boost.
Old Jan 23, 2002 | 09:35 PM
InfamousRS's Avatar
Default Re: OEM head gasket? (VaporTrail)
Really? Whats the point of all the metal and coper stuff then?
Old Jan 23, 2002 | 09:39 PM
dustin's Avatar
Some people like cheaping out and lowering compression with them but it is not the right way to do it. It also changes the distance from the crank to the cam gears so your cam timing gets off.
Lower compression with lower comp pistons, or ... just leave them
Dustin
Old Jan 23, 2002 | 10:01 PM
VaporTrail's Avatar
New User
what dustin said. I'd like to add that I Honda head gaskets!
Old Jan 24, 2002 | 03:19 AM
BLKCRX's Avatar
how much are OEM head gaskets ???
Regards James
Old Jan 24, 2002 | 05:22 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: OEM head gasket? (dustin)
Dustin
Dustin, I dont see how it would change the cam timing. Can you extrapulate this for me?
art
Old Jan 24, 2002 | 07:00 AM
rtype11's Avatar
OEM is good no dispute, but I find SCE copper with o-rings even good"er"!
Old Jan 24, 2002 | 09:12 AM
VaporTrail's Avatar
New User
Default Re: OEM head gasket? (Arturbo)
Dustin
art
Ok, you are changing the distance between the block and the head. It's just like when you mill a head or deck a block, only opposite. The extra material between the head and block would actually advance your total cam timing. Just the opposite happens when you mill/deck. This is why cam gears are important on any motor.
Old Jan 24, 2002 | 09:16 AM
dustin's Avatar
What he said.
Old Jan 24, 2002 | 11:11 AM
sgT's Avatar
sgT
Well, stock head gaskets ARE metal.
Old Jan 24, 2002 | 11:55 AM
civictom's Avatar
Default Re: OEM head gasket? (BLKCRX)
$50-$70-depending on your hook-up and the dealer
Regards James
Old Jan 24, 2002 | 02:11 PM
TurboR1391's Avatar
Default Re: OEM head gasket? (civictom)
I run 15psi on the stock head gasket and it works fine.
NoAhIDontThinkSo
Jan 25, 2011 05:43 PM
oneiro
Mar 28, 2007 08:49 PM
jdmcx
Feb 17, 2004 12:51 PM
boosted_dc2
Mar 10, 2003 07:26 PM
D16A6Turbo
Dec 1, 2002 06:16 PM
