OBD2 enigne codes? help..hondata install
Subscribe
Jun 13, 2003 | 02:04 PM
ok, i just installed hondata on my gsr. i now have a p72 ecu with the OBD1-2 connector already attached from hondta. so, the car idles really really ruff and doesnt sound good. The check engine light comes on and its a code 16. i can only find the engine codes for a b16, but i thought they might be the same. there is no code 16 on a b16, or will i now be reading OBD1 codes?
Reply 0
Jun 13, 2003 | 02:18 PM
Re: OBD2 enigne codes? help..hondata install (siis2fast)
Code 16 = Fuel Injection system
I got that code when one of the wires on one of my injectors had poked a hole in the shrink tubing.
If you have a code 16, the car will run like total crap. (as you probably saw)
Check your wiring, man.
Sonny
Reply 0
Subscribe
