OBD II and Turbo
Old Jun 27, 2002 | 10:39 AM
reXem's Avatar
Default OBD II and Turbo
Ok first off I did search but no topics about this.....
For you people with OBD2 what did you do for the secondary O2 sensor?
Old Jun 27, 2002 | 01:20 PM
Etylorcen's Avatar
Default Re: OBD II and Turbo (reXem)
What kind of question is this? You mean if you made a test pipe? If you still have a cat it goes where it is.
Old Jun 27, 2002 | 02:07 PM
Ri5e's Avatar
Default Re: OBD II and Turbo (Etylorcen)
The 2nd O2 sensor, just wrap it up with aluminum foil and shove it in the Test pipe.
Old Jun 27, 2002 | 02:13 PM
niedejb's Avatar
Default Re: OBD II and Turbo (BG Boost)
I have my hanging in mid air. I made an O2 "simulator" to send the ecu the correct millivolt range.
I didnt use the PC boards, just soldered them.
The rest is on my site below
[Modified by niedejb, 5:14 PM 6/27/2002]
Old Jun 27, 2002 | 03:41 PM
nstalr1072's Avatar
I have obd2 and no catalytic conv. I simply removed the #2 oxygen sensor (and check engine light). car runs perfect.
Old Jun 27, 2002 | 03:52 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: OBD II and Turbo (nstalr1072)
So you removed your O2 sensor and Check engine light?
art
Old Jun 27, 2002 | 04:47 PM
bigTom's Avatar
if u removed the o2 sensor and the bulb for the mil lamp so as though u wont have to look at it all the time when u drive... this does not stop the car from running in limp mode (aka running like ****)
HXMan's Avatar
Default Re: OBD II and Turbo (Arturbo)
art
Hmmm....sounds like he is saying he has a check engine light now, and it is running fine with it??
Code for secondary O2 sensor doesn't put you in limp mode.
[Modified by HXMan, 7:48 PM 6/27/2002]
Old Jun 27, 2002 | 05:02 PM
TurboCivicSi's Avatar
Loose the OBD-2 Ho Hondata.. You are looking at spending several thousand dollars fo FI, so spend another grand on an ECU upgrade, and do it right...
-Jason
[Modified by TurboCivicSi, 2:13 AM 6/28/2002]
Old Jun 27, 2002 | 06:12 PM
reXem's Avatar
Default Re: OBD II and Turbo (TurboCivicSi)
Thanks for the replys...this for a buddy and he not spending thousands on FI..he just wants a small setup to give him a little extra umph (for now anyways......he will get bitten once he feels that boost) Really I should have worded the question better I just wanted to make sure that if the O2 sensor was reading wrong that nothing would go wrong (limp mode) thanks again
Old Jun 27, 2002 | 06:50 PM
BoostinDC2's Avatar
on my 2000 gsr i just took out the o2 and zip tied it to my shift linkage and left it there and no cel's dont ask how but it never threw a cel on the stock ecu
Frstyl838
Mar 2, 2009 03:30 PM
95acuraintegra
Jan 8, 2009 04:54 PM
mystikal-vti
Jan 8, 2009 02:59 PM
Ladies Man
Jun 15, 2001 11:39 PM
