obd 2 IAT bung?
Old Apr 19, 2012 | 12:58 PM
boosted_D's Avatar
Default obd 2 IAT bung?
Not sure if I should post here or in engine management....This is the first obd 2 car I have built, it will be running obd 1 with a jumper harness and chipped p28 on neptune.
I'm wondering where I can get a fancy little bung that can be welded onto the charge pipe for the obd 2 IAT sensor, something that will hold a seal and not be a boost leak, I googled it but didnt really come up with anything....
Old Apr 19, 2012 | 01:25 PM
Turbo-LS's Avatar
Default Re: obd 2 IAT bung?
Xenocron link
http://www.xenocron.com/iat-flange-x...3ab9944f69b026
Go-auto link
http://www.go-autoworks-store.com/aliathowefl.html
Old Apr 19, 2012 | 03:41 PM
xile6's Avatar
im using a GM Open Element. Works great and people have been using them for a while.
http://www.diyautotune.com/catalog/s...70904c51a678f9
Old Apr 19, 2012 | 04:33 PM
Turbo-LS's Avatar
With what engine management? As far as i know Honda ecu based engine management requires a Honda temp sensor right?
Old Apr 19, 2012 | 04:59 PM
Tony the Tiger's Avatar
You can use a generic 1/4" NPT aluminum bung, with an O-ring that slips onto the IAT sensor, and drill a hole/tap a thread at the side for a small set screw.
I do that a lot on OBD-II IAT sensors.. I'll post up a pic later
Old Apr 20, 2012 | 05:51 AM
xile6's Avatar
Aem fic piggy back on obd2 p2p ecu. That gm senor is within range of honda, so no reprograming
Old Apr 20, 2012 | 06:50 AM
boosted_D's Avatar
In for pics when you get a chance !
chaztuna
Engine Management and Tuning
Apr 2, 2011 12:12 PM
turbo*s2k
Dec 24, 2003 08:17 AM
SpoolnG2
Jul 27, 2003 02:32 PM
the JigGa mAn
Jul 1, 2003 08:57 PM
comptechgsr2000
Jun 16, 2002 04:45 PM
