o2 sensor woes
Old Oct 19, 2009 | 06:24 PM
GReddy_Civic's Avatar
Default o2 sensor woes
So i had a 97 civic that was turbo'd. The o2 sensor was near the tranny on top. Well i got rear ended and now i have a 99. The o2 sensor is near the oil filter. I tried removing the o2 sensor from the stock exhaust but with no luck since its so oxidized. So my question is, can I just cut the plug off the 99 o2 sensor, lengthen it, and solder it to the 97 one that still works?
Old Oct 19, 2009 | 10:02 PM
Default Re: o2 sensor woes
bump
Old Oct 20, 2009 | 06:39 AM
scartail's Avatar
Originally Posted by GReddy_Civic
bump
I think you will be fine. The length does effect the resistance, and theorhetically would changes the reading. But I think it is a very small amount.
Here are some examples that support my reasoning, there are extension available and the universal oxygen sensor come as 'cut-to-length' and uses the original harness. Ideally, you want to get close in length, but really I don't think it matters much to the readings.
Both o2 sensors are 4-wire, right?
GSRacer1
Oct 21, 2003 08:14 PM
