NOS on a mInI me
Old May 19, 2005 | 06:28 PM
Otherguy's Avatar
NASIOC.com
Default NOS on a mInI me
I wanted to ask everyones opinion about this... My friend is willing to give me is Wet NOS system for a really cheap price... I would like to get it, but im not to sure if it would be the best thing for my motor... I have a Mini me setup (d15b7 block, d16y8 head) and im wondering if you guys think it could handle it? What would be best...
Old May 19, 2005 | 06:29 PM
Deemeetree's Avatar
Electrician
50 shot to play safe. No more.
Old May 19, 2005 | 06:36 PM
e jay one's Avatar
Default Re: (Dimitri_EG8 a.k.a. Dimi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Otherguy &raquo;</TD></TR><TR><TD CLASS="quote">I have a Mini me setup (d15b7 block, d16y8 head)..</TD></TR></TABLE>
sorry to change the topic but what dizzy are you using? im going to do this swap on my buddies lx (same motor same head as you). and deffinatly get the nos
Old May 19, 2005 | 06:41 PM
tkosmith's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimitri_EG8 a.k.a. Dimi &raquo;</TD></TR><TR><TD CLASS="quote">50 shot to play safe. No more.</TD></TR></TABLE>
I second that... Any more and MiniMe could go Boom. It'll be a nice little "kick" for you though.
Old May 19, 2005 | 07:02 PM
canis's Avatar
yah if you run a 50 or even a 100 and use smaller jets you should be fine..
Old May 19, 2005 | 07:13 PM
idriveadelsol7's Avatar
Default Re: NOS on a mInI me (Otherguy)
i ran 75 shots (stock) on my accord. turbo | nitrous... same ****. it's all going to own your motor sooner or later. i'm not sure so correct me if i am wrong, but the only thing automotive nitrous oxide does after you squeeze is that sulfur starts to build that cannot be burned inside of your engine. unless you can get medical-grade n2o, squeeze away. otherwise... build your transmission, because that will be the first to go.
Old May 19, 2005 | 07:18 PM
JDtiM's Avatar
how much does the mini me setup cost? with what kinda tranny?
Old May 19, 2005 | 07:25 PM
Deemeetree's Avatar
Electrician
Default Re: NOS on a mInI me (JDtiM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDtiM &raquo;</TD></TR><TR><TD CLASS="quote">how much does the mini me setup cost? with what kinda tranny?</TD></TR></TABLE>
You can find a D16Z6 or D16Y8 cylinder head, complete, in the $100-$200 range. Best transmission to use, of course, is the 1992-2000 Honda Civic EX/Si (D16Z6/D16Y8) transmission.
Old May 19, 2005 | 07:31 PM
Otherguy's Avatar
NASIOC.com
Default Re: NOS on a mInI me (Dimitri_EG8 a.k.a. Dimi)
my mini me setup cost about 600 bucks all said and done... I did all the work too, i just put alot of new parts on =D
*EDIT*
Also, what would be the best way to hook it up? because i know that im going to need to tap my fuel rail right?
Old May 19, 2005 | 08:19 PM
spockeg's Avatar
Would suggest puting a fuel pump on it. but thats it. I have been runing a 75 wet shot on my stock 95 si with 200,000 miles and all i'm Runen is a walbro. Have run about three bottles through it and have not seen any smoke or odd nosies.
Old May 19, 2005 | 09:04 PM
spockeg's Avatar
Also, what would be the best way to hook it up? because i know that im going to need to tap my fuel rail right?[/QUOTE]
I spliced mine in to my main fuel feed that runs to the fuel rail.
not sure if that is the right spot but i had seen others like that.
Old May 19, 2005 | 09:06 PM
Otherguy's Avatar
NASIOC.com
Default Re: NOS on a mInI me (spockeg)
do you have any pictures?
knockout's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimitri_EG8 a.k.a. Dimi &raquo;</TD></TR><TR><TD CLASS="quote">Best transmission to use, of course, is the 1992-2000 Honda Civic EX/Si (D16Z6/D16Y8) transmission. </TD></TR></TABLE>
Old May 20, 2005 | 07:36 AM
spockeg's Avatar
I will try to get some pics tonight and you are going to want to retared your timing. I learned that the hard way.
Old May 21, 2005 | 07:07 PM
Otherguy's Avatar
NASIOC.com
how can i tell what "shot" i have... this system was pulled of a 99 si...
Old May 22, 2005 | 10:24 AM
spockeg's Avatar
There will be #s on the jets. Depending on the kit (NOS, NX, ex) the #s will mean a shot. Depending on the kit go search for jet sizes.
and still trying to get some pics
Old May 22, 2005 | 12:42 PM
spockeg's Avatar
Here's a pic Hope it helps
Old May 22, 2005 | 01:42 PM
MidShipCivic's Avatar
Default Re: NOS on a mInI me (idriveadelsol7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by idriveadelsol7 &raquo;</TD></TR><TR><TD CLASS="quote">i ran 75 shots (stock) on my accord. turbo | nitrous... same ****. it's all going to own your motor sooner or later. i'm not sure so correct me if i am wrong, but the only thing automotive nitrous oxide does after you squeeze is that sulfur starts to build that cannot be burned inside of your engine. unless you can get medical-grade n2o, squeeze away. otherwise... build your transmission, because that will be the first to go.</TD></TR></TABLE>
This is bull.
Old May 22, 2005 | 02:40 PM
Otherguy's Avatar
NASIOC.com
Default Re: NOS on a mInI me (MidShipCivic)
i must be retarted or something... where are the jets at?
Old May 22, 2005 | 02:43 PM
SOHC_MShue's Avatar
why can't you use more than a 50 shot? If people can push over 200whp on a stock block mini-me then i don't see why they can't shoot a bigger shot of nitrous. Tuning is key.
Old May 22, 2005 | 02:48 PM
Otherguy's Avatar
NASIOC.com
Default Re: (SOHC_MShue)
i dont want to blow my **** so im using 50.. 2 questions.... The kit is a NOS one... It has one fogger but im just trying to find the jets... I think they are on the fogger thingy... but im not 100 sure. Also what is the best spot to mount the hardware?
Old May 22, 2005 | 04:46 PM
SOHC_MShue's Avatar
Default Re: (Otherguy)
Tune it and you won't blow your **** with a bigger shot.
Old May 22, 2005 | 04:58 PM
Otherguy's Avatar
NASIOC.com
well duh im going to tune it =D...
Old May 22, 2005 | 05:17 PM
SOHC_MShue's Avatar
then go for a bigger shot
Old May 23, 2005 | 10:05 AM
spockeg's Avatar
if it is a wet kit both jets will be in the nozel. If you undo the feed line to the nozel you will see them sitting in it.
If it is a dry kit one will be in the nozel and the othe should go in the vacum line off your FPR not 100% sure on dry kits i do not mess with them because there not as safe as a wet kit.
