Noob needs help installing external wastegate to manifold
Old Sep 22, 2007 | 02:14 AM
Powelly's Avatar
Default Noob needs help installing external wastegate to manifold
Can anyone help me out with this?
I mock it up using the thick metal bracket & gasket but then the screws are no way long enough to secure it to the manifold.
Are these metal bracket parts essential or can i just use the thin gasket and bolt it direct to the manifold?
I know im doing something wrong so if someone could help me out?
Thanks
Old Sep 22, 2007 | 02:22 AM
mercutio_07's Avatar
Default Re: Noob needs help installing external wastegate to manifold (Powelly)
you can go to the local hardware store and get longer screws if needed. i believe they're M8 and the pitch is fine 1.25
Old Sep 22, 2007 | 04:19 AM
reaction360's Avatar
Default Re: Noob needs help installing external wastegate to manifold (mercutio_07)
are you talking about the spare flanges that are meant for your dumptube and the other meant to be welded onto manifolds without an external wastegate flange? because all you need is the gasket to bolt the wastegate on.
-Zol
Old Sep 22, 2007 | 06:19 AM
red_crx's Avatar
Default Re: Noob needs help installing external wastegate to manifold (reaction360)
ok, your going to have to buy 2 bolts and 2 nuts to install the wastegate to the manifold (flange on the manifold doesn't look threaded). You will just need a gasket if even that; I don't use a gasket on mine.
Old Sep 22, 2007 | 07:10 AM
Powelly's Avatar
Sorted. Thanks for clearing that up.
Old Sep 23, 2007 | 12:41 PM
dek1mfk's Avatar
Default Re: (Powelly)
all u need is the thin gasket the little ring and the 2 screws the rest is for the dumptube.
Legion
Jun 7, 2008 08:59 PM
zimmy666
Apr 29, 2007 08:44 AM
trbob16a
Feb 5, 2004 05:45 AM
cajnatc
May 11, 2003 10:59 AM
