Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Forced Induction (https://honda-tech.com/forums/forced-induction-16/)
-   -   NEW oil feed line question. (https://honda-tech.com/forums/forced-induction-16/new-oil-feed-line-question-126335/)
Smashback Feb 7, 2002 07:52 PM
I have a 1 ft -4 line to a t fitting, which obviously tees off to another -4 line to the turbo and also to the stock pressure sending unit. Will pressure be affected depending on how you tee the line? I.E. -
----T----
pressure sender
vs.
----T-pressure sender
Make sense? I know the "diagrams" aren't showing up right, but...
Any info guys?
[Modified by mplex2000, 4:52 AM 2/8/2002]
[Modified by mplex2000, 4:53 AM 2/8/2002]
Smashback Feb 7, 2002 08:07 PM
Re: NEW oil feed line question. (mplex2000)
C'mon guys, any ideas? I'm about to go out in the freezing ass garage to swap mine around to see if it makes any difference. Let me know if I should not bother.
98Psi ITR Feb 7, 2002 08:13 PM
I'd pick the first diagram.
Smashback Feb 7, 2002 08:22 PM
Re: NEW oil feed line question. (98Psi ITR)
Argh, that's the way I have it now. I really have my doubts as to whether it makes a difference, but I think I'm gonna try switching it.
Giuseppe Feb 7, 2002 08:32 PM
block------T-----turbo
........sending unit.....
as opposed to:
block..........T.........sending unit
...............turbo.......
is this what u mean...??
beacause theres no difference...!
[Modified by Giuseppe, 5:34 AM 2/8/2002]
Smashback Feb 7, 2002 09:21 PM
Re: NEW oil feed line question. (Giuseppe)
That's what I figured, six to one half dozen the other but I changed it anyway. At least it made things a little neater!
Giuseppe Feb 8, 2002 01:23 AM
what does this mean..???!?!
GruvyTune Feb 8, 2002 03:48 AM
the phrase is "6 or one half dozen of the other".
anyway, I just went through all this in 25 degree weather outside. I actually had a small metal frag plugging my oil feed line. All ok now although i may be rebuilding my turbo sooner due to only a trickle of oil flow.
I have mine Teed off the block with the sending unit on the T and a -3 line coming off the T to the turbo. I then put another T at the end of the feed line and connected a Greddy pressure sender there and another -3 line to the turbo. I measure max pressures there of about 35psi at most rpms (-3 line seems to limit pressures) and lowest pressures at idle of about 15psi.
torin
Smashback Feb 8, 2002 07:12 AM
Re: NEW oil feed line question. (GruvyTune)
I think I am going to change out the longer -4 line with a -3, because it appears I' getting a little oil past the seals once or twice a day when the car puffs smoke as I take off in 1st. Hopefully I don't need a rebuild already.
HXMan Feb 8, 2002 08:21 AM
block-----T-----turbo
P sender
This setup looks like it will have a better flow to the turbo. The oil doesn't have to make a right hand turn.
Giuseppe Feb 8, 2002 11:17 AM
u still didnt explain the phrase.!!
what does it mean.!!
GruvyTune Feb 8, 2002 02:00 PM
It means you can take 6 OR a 1/2 dozen which mathematically is the same thing. Simple.
Giuseppe Feb 8, 2002 06:17 PM
http://www.ubrf.org/phpBB/images/smiles/icon_tfg.gif
Smashback Feb 8, 2002 06:25 PM
But not half or 50% as gay as a 1g DSM BOV!
Giuseppe Feb 8, 2002 06:26 PM
Re: NEW oil feed line question. (HXMan)
actually if we really want to get technical
..........P sender
the path of less resistance is infact that right angle turn,
because the oil would have to 'jump' another 1/4 inch to span
the T fitting gap,
the only way the pic above is 'better' is if the T was facing upwards
and the oil had to travel against gravity...!
but then u could say that the sending unit has static flow, because its a 'dead end' and a straight line would work best...this is right too, ahh, WFC...
Giuseppe Feb 8, 2002 06:27 PM
thats the thanks i get for helping u out..
my comment wasnt towards you, but the phrase...
chill.!
DragII Feb 8, 2002 06:28 PM
some call it six, some call it half a dozen.
some say potaytoe, some say potahtoe
and some post dumbass pictures for no apparent reason
http://images.zeroforum.com/smile/emwink.gif
Giuseppe Feb 8, 2002 06:37 PM
Re: NEW oil feed line question. (DragII)
now we got the police involved, sorry officer.! http://images.zeroforum.com/smile/emwink.gif
DragII Feb 8, 2002 06:43 PM
http://images.zeroforum.com/smile/emsmileo.gif
Smashback Feb 8, 2002 06:50 PM
Joking, joking, trying to make a joke my freind.
So here's another question -
I think someone asked something similar already. If I replace the longer length og -4 hose with -3, will it possibly stop the once every day or two that my car decides to blow some oil thru the turbo? It's definitely coming from the turbo, not the engine, but I need to figure out how to stop it.
Giuseppe Feb 8, 2002 07:10 PM
lol, i was joking too, just being sarcastic.. http://images.zeroforum.com/smile/emsmile.gif
yeah try the -3AN line or keep the -4AN line
and use a restrictor to reduce the flow of oil..
either place the reducer at the T of just before the turbo
i say try whichever methods is cheapest.. http://images.zeroforum.com/smile/emwink.gif
hence the cheap DSM BOV, all it does is fart air.. http://images.zeroforum.com/smile/emwink.gif
good luck.!
