NEW oil feed line question.
Old 02-07-2002, 07:52 PM
Smashback's Avatar
Default NEW oil feed line question.
I have a 1 ft -4 line to a t fitting, which obviously tees off to another -4 line to the turbo and also to the stock pressure sending unit. Will pressure be affected depending on how you tee the line? I.E. -
----T----
pressure sender
vs.
----T-pressure sender
Make sense? I know the "diagrams" aren't showing up right, but...
Any info guys?
[Modified by mplex2000, 4:52 AM 2/8/2002]
[Modified by mplex2000, 4:53 AM 2/8/2002]
Old 02-07-2002, 08:07 PM
Smashback's Avatar
Default Re: NEW oil feed line question. (mplex2000)
C'mon guys, any ideas? I'm about to go out in the freezing *** garage to swap mine around to see if it makes any difference. Let me know if I should not bother.
Old 02-07-2002, 08:13 PM
98Psi ITR's Avatar
I'd pick the first diagram.
Old 02-07-2002, 08:22 PM
Smashback's Avatar
Default Re: NEW oil feed line question. (98Psi ITR)
Argh, that's the way I have it now. I really have my doubts as to whether it makes a difference, but I think I'm gonna try switching it.
Old 02-07-2002, 08:32 PM
Giuseppe's Avatar
block------T-----turbo
........sending unit.....
as opposed to:
block..........T.........sending unit
...............turbo.......
is this what u mean...??
beacause theres no difference...!
[Modified by Giuseppe, 5:34 AM 2/8/2002]
Old 02-07-2002, 09:21 PM
Smashback's Avatar
Default Re: NEW oil feed line question. (Giuseppe)
That's what I figured, six to one half dozen the other but I changed it anyway. At least it made things a little neater!
Old 02-08-2002, 01:23 AM
Giuseppe's Avatar
what does this mean..???!?!
Old 02-08-2002, 03:48 AM
New User
GruvyTune's Avatar
the phrase is "6 or one half dozen of the other".
anyway, I just went through all this in 25 degree weather outside. I actually had a small metal frag plugging my oil feed line. All ok now although i may be rebuilding my turbo sooner due to only a trickle of oil flow.
I have mine Teed off the block with the sending unit on the T and a -3 line coming off the T to the turbo. I then put another T at the end of the feed line and connected a Greddy pressure sender there and another -3 line to the turbo. I measure max pressures there of about 35psi at most rpms (-3 line seems to limit pressures) and lowest pressures at idle of about 15psi.
torin
Old 02-08-2002, 07:12 AM
Smashback's Avatar
Default Re: NEW oil feed line question. (GruvyTune)
I think I am going to change out the longer -4 line with a -3, because it appears I' getting a little oil past the seals once or twice a day when the car puffs smoke as I take off in 1st. Hopefully I don't need a rebuild already.
Old 02-08-2002, 08:21 AM
HXMan's Avatar
block-----T-----turbo
P sender
This setup looks like it will have a better flow to the turbo. The oil doesn't have to make a right hand turn.
Old 02-08-2002, 11:17 AM
Giuseppe's Avatar
u still didnt explain the phrase.!!
what does it mean.!!
Old 02-08-2002, 02:00 PM
New User
GruvyTune's Avatar
It means you can take 6 OR a 1/2 dozen which mathematically is the same thing. Simple.
Old 02-08-2002, 06:17 PM
Giuseppe's Avatar
Old 02-08-2002, 06:25 PM
Smashback's Avatar
But not half or 50% as gay as a 1g DSM BOV!
Old 02-08-2002, 06:26 PM
Giuseppe's Avatar
Default Re: NEW oil feed line question. (HXMan)
actually if we really want to get technical
..........P sender
the path of less resistance is infact that right angle turn,
because the oil would have to 'jump' another 1/4 inch to span
the T fitting gap,
the only way the pic above is 'better' is if the T was facing upwards
and the oil had to travel against gravity...!
but then u could say that the sending unit has static flow, because its a 'dead end' and a straight line would work best...this is right too, ahh, WFC...
Old 02-08-2002, 06:27 PM
Giuseppe's Avatar
thats the thanks i get for helping u out..
my comment wasnt towards you, but the phrase...
chill.!
Old 02-08-2002, 06:28 PM
DragII's Avatar
some call it six, some call it half a dozen.
some say potaytoe, some say potahtoe
and some post dumbass pictures for no apparent reason
Old 02-08-2002, 06:37 PM
Giuseppe's Avatar
Default Re: NEW oil feed line question. (DragII)
now we got the police involved, sorry officer.!
Old 02-08-2002, 06:43 PM
DragII's Avatar
Old 02-08-2002, 06:50 PM
Smashback's Avatar
Joking, joking, trying to make a joke my freind.
So here's another question -
I think someone asked something similar already. If I replace the longer length og -4 hose with -3, will it possibly stop the once every day or two that my car decides to blow some oil thru the turbo? It's definitely coming from the turbo, not the engine, but I need to figure out how to stop it.
Old 02-08-2002, 07:10 PM
Giuseppe's Avatar
lol, i was joking too, just being sarcastic..
yeah try the -3AN line or keep the -4AN line
and use a restrictor to reduce the flow of oil..
either place the reducer at the T of just before the turbo
i say try whichever methods is cheapest..
hence the cheap DSM BOV, all it does is fart air..
good luck.!
memorybox
12-06-2006 03:14 PM
Del_Slowest
11-20-2003 11:55 AM
SuzukaBlueAP2
07-07-2003 02:36 PM
808eg6
01-25-2002 01:48 PM
Quick Reply: NEW oil feed line question.
