New motor won't start!!!
Old May 3, 2003 | 10:37 PM
Cornbread Jr.'s Avatar
Default New motor won't start!!!
After waiting 2 months I finally picked up my motor from Jotech today. After we put it in and finished everything, it wouldn't start. It just kept tunring over, but would never catch. When I gave it a little gas it would try to turn over, but it also made a horrible clanking noise from the motor. I have no idea what's going on. It's a fully built GS-R with RS Machine sleeves, Crower rods, Arias 9.5:1 pistons, Skunk2 valve springs and retainers, and Rev valves. I'm so pissed off. Hopefully it's nothing major, but I've had bad luck lately. I guess I'll just have to tow it to Jotech Monday and have Tony look at it. I don't fell like even working on it tomorrow. Sorry for the long post, but I just had to vent. If anyone has any idea as to what's wrong, I'm open to suggestions.
Old May 3, 2003 | 10:39 PM
psi420's Avatar
I know it may sound stupid, but do you have a spark?
And if so, is your firing order correct?
Old May 3, 2003 | 10:57 PM
Default Re: (psi420)
Yeah it does, I double checked that after it wouldn't start when we first tried it. Even if that was the problem it still doesn't explain the noise coming from the motor.
Old May 3, 2003 | 11:06 PM
boosted hybrid's Avatar
Default Re: (Cornbread Jr.)
Where the valves adjusted?
You might be losing to much compression if the valves are out of adjustment, hence the reason that you cannot build enough pressure in the cylinders to have the car start.
There are so many variables and things that it could be. Jotech is very knowledgable shop, I would feel pretty confident their engine build is top notch.
Old May 3, 2003 | 11:11 PM
Default Re: (boosted hybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted hybrid &raquo;</TD></TR><TR><TD CLASS="quote">Where the valves adjusted?</TD></TR></TABLE>
I assume they were. I hda Jotech do everything and I would think that they wouldn't forget to adjust the valves. I know Jotech deos great work. I've been going there for about 5 years. I trust that they will take care of whatever's wrong. I'm not mad at them, just frustrated.
Old May 3, 2003 | 11:13 PM
ImportReview
Guest
Posts: n/a
Default Re: New motor won't start!!! (Cornbread Jr.)
This is why you pay a shop $800 to install it and get it running for you.
You could have hurt the motor already. It pays to have professionals install very expensive motors.
Thats not Jotech's responsibility, they should be paid to do that job. You might want to make a gesture to pay them money to look at it and make it run.
Good shops like Jotech need to make money too, nobody likes working for free.
If you ask me, that horrible noise is no oil in the oil pump gear when it turns, it sounds HORRIBLE...unless it fills with oil.
Thats just my advice. You can call me all the names you want now.
Jeff
Old May 3, 2003 | 11:44 PM
Default Re: New motor won't start!!! (ImportReview)
I'm not going to call you names. Trust me, I wish now that Jotech had installed the engine. I already paid to have the motor installed once, I just wanted to save money. I have no problem with paying them, but I think that if it doesn't even start on the first try, it's really not my fault. One of the guys that works there is coming out to help me with it tomorrow. Hopefully he can help diagnose the problem.
Old May 4, 2003 | 12:10 AM
ImportReview
Guest
Posts: n/a
I understand.
I have alot of experience with these kinds of things, and believe me, it PAYS to pay BIG BUCKS to a shop to get something important to you running.
I bet its your oil pump, watch. As soon as it fills with oil, sound goes away.
Jeff
Old May 4, 2003 | 12:15 AM
psi420's Avatar
So you do have spark then.
Then I guess go down the rest of the list.
Compression?
Fuel?
Air?
Timing?
Only other thing I can think of if all is well......try another known good ECU.
Old May 4, 2003 | 12:27 AM
ninesecrx's Avatar
check to make sure you have fuel pressure and check all your grounds. Its real easy to over look that and it might not fire. Last but not least make sure you didnt get the tps and map plugs backward.
and my guess on the noise, its the Arias pistons. No oil and they are cold...they will always clack.
Old May 4, 2003 | 01:09 AM
psi420's Avatar
Default Re: (ninesecrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ninesecrx &raquo;</TD></TR><TR><TD CLASS="quote">check all your grounds. Its real easy to over look that and it might not fire. Last but not least make sure you didnt get the tps and map plugs backward.
.</TD></TR></TABLE>
Yah, those are some good ones too.
Old May 4, 2003 | 01:55 AM
MiraiZ's Avatar
I put my money on either the valves not being adjusted (doubt that they did this) or your injectors not sending fuel..
Old May 4, 2003 | 06:35 AM
ekb18c's Avatar
It's probably something simple that you might have overlooked.
Well take it as a lesson learned: Don't Cheap out on an expensive motor.
btw-why didnt you prime the new motor before trying to start it?
Old May 4, 2003 | 07:48 AM
sweet's Avatar
Default Re: New motor won't start!!! (ekb18c)
the first things that come to mind to check are the spark and fuel.
make sure the firing order is correct and that there is spark to begin with.
also make sure there is fuel and the injectors are firing.
what kind of ignition and fuel systems are you using right now?
some of the other points mentioned are very good, like checking electrical connections such as the grounds and the valves needing an adjustment.
Old May 4, 2003 | 09:58 AM
Default Re: New motor won't start!!! (Baddasss)
Thanks for all the input. I did prime the engine before trying to start it. I did this with the ECU, injectors, and spark plugs removed. As far as what I'm using, I have a Vortech 12:1 fmu, MSD inline fuel pump, MSD digital 6 ignition system, and stock injectors. I'm just using the fmu and inline pump during the break-in period untill I can get my Hondata tuned on the dyno. I might try a new ECU today and I guess I can check all the connections one more time. I'll let you guys know what happens.
Old May 4, 2003 | 10:23 AM
espanol's Avatar
Good luck on getting it started and breaking it in
Old May 4, 2003 | 10:41 AM
DIRep972's Avatar
Smarter than you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ImportReview &raquo;</TD></TR><TR><TD CLASS="quote">This is why you pay a shop $800 to install it and get it running for you.
Jeff
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ImportReview &raquo;</TD></TR><TR><TD CLASS="quote">I understand.
Jeff
I agree with this guy. what do u think u were doing trying to install a motor on ur own? geeez, only superhumans can install motors. You should have PAID.. BIG BUCKS.. to have the shop do it.
anyways, try checking the fuses, it could be simple as that. good luck scott.
Old May 4, 2003 | 10:52 AM
Flamenco-T's Avatar
I didn't know it was you scott...
well, yeah, 99% of the time, it is something simple, such as fuse, bad ground and etc like that.
if you get sick of it, walk away, do soemthing else, then come back to it after you chill for a while...you'll be okay
stan
Old May 4, 2003 | 11:32 AM
quikB18B's Avatar
Default Re: New motor won't start!!! (Flamenco-T)
I just wanna know what the fawking problem is Im curious, het scott its iggy btw, wheres tony1 does he have any input. Keep us posted
Old May 4, 2003 | 12:22 PM
Flamenco-T's Avatar
Default Re: New motor won't start!!! (quikb20)
tony is in E-town..
stan
Old May 4, 2003 | 12:44 PM
Mase's Avatar
check every single fuse like stan said
Old May 4, 2003 | 03:43 PM
sparkz's Avatar
Default Re: New motor won't start!!! (Mase)
how about dbl check to see if the timing belt didnt slip?
Old May 4, 2003 | 04:41 PM
Default Re: New motor won't start!!! (sparkz)
Andrew from Jotech (for those of you who know him) just finished looking at it. We still couldn't figure it out. We pulled off the valve cover and looked for anything wrong and couldn't find anything. I'm towing it to Jotech tomorrow. I know Tony can figure it out. I'll keep you guys posted.
Old May 4, 2003 | 06:13 PM
MiraiZ's Avatar
Default Re: (MiraiZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiraiZ &raquo;</TD></TR><TR><TD CLASS="quote">I put my money on either the valves not being adjusted (doubt that they did this) or your injectors not sending fuel..</TD></TR></TABLE>
anybody taking bets?
Old May 4, 2003 | 06:55 PM
bottlefedb18c1's Avatar
my freinds car did the same thing but the thing was it was going down the track and they pushed it off
there was no spark and he had the msd on there and he disconcted it back to stock and still didnt start i had bad 6 BTM's in the past myself after that check power to the coil and if you dont have power to the coil the big black yellow wire to the dis. i beilive it is check the ignition fuse under the dash that was my freinds problem he was about to get it towed but it was only a fuse
