Need some help from tuners or engine buliders
Old Mar 12, 2008 | 02:12 PM
DLB1994's Avatar
Default Need some help from tuners or engine buliders
I've been building engine for many years and every thing u can name but i cant seem where to point the finger on this one .. heres the info ..
its a H motor car was on a good ok tune but was very rich 11.5-10.8 air/fuel
reving to 7500 rpms .. 15psi made 440whp on that very rich tune
I looked at his hondata map timing was around 25dreg on 110 octane
i pulled the engine apart for him just to check every thing out for the new season still ran fine before pulled . bearing looked good and all so i pull the rods out and look what i find (pics under).. all 4 rods bend oddy .. there IB rods I beam..
so now what im asking is do u think it was the cheap rods or the tune. I trying to figg out what to do since he needs new rods , its a h23 crank so theres not many rods out there crower or these and he do not want to spend the money on crower if he do not have to... let me know yah thoughts
Old Mar 12, 2008 | 02:24 PM
IN VTEC's Avatar
Default Re: Need some help from tuners or engine buliders (DLB1994)
Look at the small-end bushing, wrist pin, and conrod bearings. If they are scuffed or show signs of contact with the crank, then I wouldn't rule out the tune.
Old Mar 12, 2008 | 02:35 PM
Schister66's Avatar
Man U FTW
I've never seen that before...in for more info
Old Mar 12, 2008 | 03:18 PM
ExospeedAMcrx's Avatar
Iheard that was called the S-beam rod.
Old Mar 12, 2008 | 10:52 PM
DLB1994's Avatar
no one can chime in?
Old Mar 13, 2008 | 03:10 AM
non-VTEC's Avatar
Default Re: (DLB1994)
wow those rods are bent to ****.......poor qualitly? or maybe the I beams are not meant to handle that kind of stress?
use a good set of H beams?
email jeff at IB and show him the pictures.....see what he says.
Old Mar 13, 2008 | 06:29 AM
DLB1994's Avatar
Default Re: (non-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">wow those rods are bent to ****.......poor qualitly? or maybe the I beams are not meant to handle that kind of stress?
email jeff at IB and show him the pictures.....see what he says.</TD></TR></TABLE>
yeh i didnt want to start pointing fringers yet.. i know that the crowers are I beams
but on there site it says that I beams are made for allmotor.. so i know what there going to say
Im trying to figg out of theres any other reason this has happen , and has any one had this on a name brand rod
Old Mar 13, 2008 | 04:31 PM
DLB1994's Avatar
Old Mar 13, 2008 | 05:10 PM
EARLdaSQUIRREL's Avatar
official honda whore
looks like it was just too much power for the rods which led to them bending which effectively led to lower compression...
id go with a better rod so this doesnt happen again...
any signs of detonation on the bearings or pistons, combustion chamber or spark plugs?
Old Mar 13, 2008 | 11:18 PM
DLB1994's Avatar
Default Re: (EARLdaSQUIRREL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EARLdaSQUIRREL &raquo;</TD></TR><TR><TD CLASS="quote">looks like it was just too much power for the rods which led to them bending which effectively led to lower compression...
any signs of detonation on the bearings or pistons, combustion chamber or spark plugs?</TD></TR></TABLE>
naw not really .. every thing look some what clean. only other thing i know about it is that he blew 2 headgaskets in the pass with this block he told me ..
but the main thing i was thinking can to much fuel with a long stroke that cause this?
Old Mar 14, 2008 | 11:28 PM
DLB1994's Avatar
so in 3days ,, no one can give me any info ??.. i know i cant be the only person who has seen this!
Old Mar 15, 2008 | 02:32 AM
RACEPAK's Avatar
id say poor quality,
Old Mar 15, 2008 | 07:01 AM
tricura's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DLB1994 &raquo;</TD></TR><TR><TD CLASS="quote">
did he blow head gaskets with those rods in the block before?
Old Mar 15, 2008 | 07:55 AM
SOHC_MShue's Avatar
damn those must be Fadi's rods. Thats no good
Old Mar 15, 2008 | 08:12 AM
DLB1994's Avatar
Default Re: Need some help from tuners or engine buliders (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">damn those must be Fadi's rods. Thats no good </TD></TR></TABLE>
naw its a guy from nova h23 vtec.. i have eagles in fadi car
Old Mar 15, 2008 | 08:13 AM
DLB1994's Avatar
Default Re: (tricura)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tricura &raquo;</TD></TR><TR><TD CLASS="quote">
did he blow head gaskets with those rods in the block before?</TD></TR></TABLE>
yeh it happen with these rods
Old Mar 15, 2008 | 08:22 AM
alpha's Avatar
Old Mar 15, 2008 | 08:33 AM
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DLB1994 &raquo;</TD></TR><TR><TD CLASS="quote">naw its a guy from nova h23 vtec.. i have eagles in fadi car</TD></TR></TABLE>
Ahh i gotcha. Yea i just asked him about it. Sounded similar because he had that headgasket issue and made similar power.
Old Mar 15, 2008 | 08:54 AM
DLB1994's Avatar
Ahh i gotcha. Yea i just asked him about it. Sounded similar because he had that headgasket issue and made similar power. </TD></TR></TABLE>
yeh he blew a headgasket running 22psi on a 15psi tune on pump gas lol
after he allready made 420's on 15psi
Old Mar 15, 2008 | 12:22 PM
DRIVENRacing's Avatar
even all motor rods would hold 400whp.. how long has he ran the car, crank walk?? thrust washers were still in when u pulled the crank?
Old Mar 15, 2008 | 01:15 PM
DLB1994's Avatar
Default Re: (DRIVENRacing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DRIVENRacing &raquo;</TD></TR><TR><TD CLASS="quote">even all motor rods would hold 400whp.. how long has he ran the car, crank walk?? thrust washers were still in when u pulled the crank?</TD></TR></TABLE>
yeh i thought crank walk to when i 1st seen it . but thrust washers were still in there and all .. i have used these rods before on a 500whp b18c .. but i know they have a better rod to stroke ratio
Old Mar 15, 2008 | 04:42 PM
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DLB1994 &raquo;</TD></TR><TR><TD CLASS="quote">yeh he blew a headgasket running 22psi on a 15psi tune on pump gas lol
after he allready made 420's on 15psi </TD></TR></TABLE>
yea i heard. It boost spiked didn't it?
Old Mar 15, 2008 | 05:33 PM
DLB1994's Avatar
yea i heard. It boost spiked didn't it? </TD></TR></TABLE>
something like that.. went from a 2.5inch downpipe to a 3 inch didnt touch the boost controller and did it by it self
the 2.5 had a nasty bend at the turbo tho ... thats why the 3inch free'd up so much more .. i been telling him we need to get back on the dyno or buy a wideband since we dont know how much more power that free'd up .. so it could be lil leaner at the same boost .. but its not my call or car
Old Mar 15, 2008 | 11:48 PM
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DLB1994 &raquo;</TD></TR><TR><TD CLASS="quote">something like that.. went from a 2.5inch downpipe to a 3 inch didnt touch the boost controller and did it by it self
the 2.5 had a nasty bend at the turbo tho ... thats why the 3inch free'd up so much more .. i been telling him we need to get back on the dyno or buy a wideband since we dont know how much more power that free'd up .. so it could be lil leaner at the same boost .. but its not my call or car </TD></TR></TABLE>
yea man i agree. It could very well be lean if the larger exhaust is causing it to creep that much more on boost.
Old Mar 16, 2008 | 11:44 AM
mRek9R's Avatar
damn, i've never seen anything like that before. in for more details...8)
