Need some help with calculating compression ratio
Old Mar 3, 2013 | 02:13 PM
hovic's Avatar
Default Need some help with calculating compression ratio
Hey guys.
I´ve searched alot and tried the zealautowerks compression calculator but couldn´t calculate the compression ratio.
I´ve got some 83mm CP pistons (8.5:1 for B18C block, B18B Crank and B18C1 head)
Since I want to go with a sleeved B16A2 block and B16A2 head instead with the B18C combo I would like to know the new compression ratio with theese pistons installed in the B16. The pistons have never been used. The PN is 76834.
Compression Hight 1.181
bore 3.268
dish depth -0.165
dome hight 0
Would be great if someone can help me out with my problem.
Old Mar 3, 2013 | 10:22 PM
civicsitek GanGsTa's Avatar
Default Re: Need some help with calculating compression ratio
I come up with 8.3:1 using b16 block crank and rods using -8 cc dish and 30mm compression height
Old Mar 5, 2013 | 12:18 PM
hovic's Avatar
Originally Posted by civicsitek GanGsTa
Pistons won't work. B16 deck height is too short. LS crank and rods with those pistons will slam into the head.
Thats why I want to use the B16 crank and rods ;-)
Old Mar 5, 2013 | 12:42 PM
Turbo-LS's Avatar
www.zealautowerks.com
IF YOU INPUT ALL THE CORRECT INFORMATION IT WILL GIVE YOU ALL THE INFORMATION YOU NEED
Old Mar 5, 2013 | 12:59 PM
MRGRIM's Avatar
R.I.P. Mark
http://www.zealautowerks.com/bseries.html
if your just useing stock parts try this
Old Mar 6, 2013 | 10:47 AM
hovic's Avatar
Originally Posted by hovic
Hey guys.
Old Mar 6, 2013 | 10:48 AM
hovic's Avatar
.....I´ve got some 83mm CP pistons (8.5:1 for B18C block, B18B Crank and B18C1 head)
Old Mar 6, 2013 | 10:59 AM
Muckman's Avatar
Moderator in Chief
Its probably bc CP's piston catalog is horrible and for some reason they don't feel it's necessary to list important specs such as dome volume so people cannot accurately calculate compression. Contact CP, get the volume in CCs and go back to Zealwerks.
GT500FTW
Dec 18, 2012 11:59 AM
7rrivera7
Jan 25, 2010 06:45 PM
champLSinteg
Jun 5, 2007 07:27 PM
GRIMEY.STREET.RACER
Sep 5, 2002 03:41 AM
