Need a sleeved b18c block
Old May 17, 2004 | 09:31 AM
sky88's Avatar
Default Need a sleeved b18c block
i need a sleened b18c block which can fit 83 piston.T03 04 e hybrid turbo 57 tim 0.50 0.63 stage 3 turbin wheel what is the range of hp it surports?
Old May 17, 2004 | 09:40 AM
TurboB18C1's Avatar
Default Re: Need a sleeved b18c block (sky88)
depending on your goals a good sleeved block would could support up 30 psi of boost or more .. check out AEBS website..
they offer block work starting from 1000 to 1500 $$
Old May 17, 2004 | 09:41 AM
Rod.'s Avatar
go with earl
Old May 17, 2004 | 10:01 AM
turbo*s2k's Avatar
Default Re: Need a sleeved b18c block (redturbocivic)
If I ever build another motor. I will go through Earl!
Old May 17, 2004 | 10:03 AM
FOrSfEd's Avatar
Default Re: Need a sleeved b18c block (TurboChrgd_Civic)
benson sleeved blocks are the best, talk to Earl
Old May 17, 2004 | 10:25 AM
sky88's Avatar
is the surport range of my turbo 250-550 hp? i know earl but i need a 2nd hand sleeved b18c block 83 mm piston
Old May 17, 2004 | 10:28 AM
Irishweird00's Avatar
Banned
to bad you need 83mm bore... I have a b18B for sale from Earl
Old May 17, 2004 | 10:53 AM
sky88's Avatar
Default Re: Need a sleeved b18c block (Irishweird00)
but i need ab 18c
Corinthians
Oct 8, 2004 10:39 AM
dy5c00
Sep 8, 2004 07:04 PM
gulftiresinc
Aug 13, 2004 04:12 AM
metal-x
Feb 10, 2003 01:54 PM
