In need of a lilttle intake manifold advice.....
Old Feb 21, 2005 | 08:07 PM
turboH22Aakkord's Avatar
Default In need of a lilttle intake manifold advice.....
hi, its just about that time... time to break down and buy an intake manifold... i really like the skunk2 and i was planning on buying untill my budy said that he had heard that they should be called "junk2" .... i was just wondering what intake mani seems to work really well for a boosted h22.... like venom or what? i mean dishing out 300 bucks is a big deal for me... so i want to spend it on the right ****... thanks in advance ...
Old Feb 22, 2005 | 09:08 AM
Default Re: In need of a lilttle intake manifold advice..... (turboH22Aakkord)
no advice? i just kinda wanted to know if the skunk2 intake mani was a good idea to use... or if there is a better intake mani to go with.. thanks....
Old Feb 22, 2005 | 09:36 AM
beepy's Avatar
If you ask me, a manifold is a manifold. They will affect how the engine responds when not in boost, but the only requirement when in boost is for the manifold to flow enough to meet your RPM limit.
If you are maintaining a close-to-OEM rev limit, keep the OEM manifold. The small ports and long runners will help you maintain some low-end, which otherwise might be lost with the altered exhaust, etc.
If the turbo can spool quickly, it doesn't matter much if the manifold causes a restriction. You can always tune the turbo's output to compensate.
Old Feb 22, 2005 | 09:40 AM
tgreaves's Avatar
I have seen many people have great luck with the new Edelbrock manifolds..
Old Feb 22, 2005 | 09:49 AM
Default Re: In need of a lilttle intake manifold advice..... (beepy)
so you think the h22's 2 piece intake mani should be ok for me right now while runin low boost? thanks for the response...
Old Feb 22, 2005 | 09:50 AM
Default Re: In need of a lilttle intake manifold advice..... (tgreaves)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">I have seen many people have great luck with the new Edelbrock manifolds..</TD></TR></TABLE>
ive heard some stuff about the edelbrock.. saying they are good and stuff.. but i cant seem to find where to buy um! haha.. any help? thanks for the response...
Old Feb 22, 2005 | 09:52 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboH22Aakkord &raquo;</TD></TR><TR><TD CLASS="quote">
ive heard some stuff about the edelbrock.. saying they are good and stuff.. but i cant seem to find where to buy um! haha.. any help? thanks for the response... </TD></TR></TABLE>
Pm'd you..
Old Feb 23, 2005 | 11:06 AM
pm'd back.. thanks!!
Old Feb 23, 2005 | 11:59 AM
DragSource's Avatar
The eldebrock manifold only helps in the WAY high RPM's - I wouldn't recommend it if you are not revvvvvvvvin' over the factory limit.
Old Feb 23, 2005 | 12:05 PM
tgreaves's Avatar
Default Re: (DragSource)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DragSource &raquo;</TD></TR><TR><TD CLASS="quote">The eldebrock manifold only helps in the WAY high RPM's - I wouldn't recommend it if you are not revvvvvvvvin' over the factory limit.</TD></TR></TABLE>
I have always seen them work well on boosted engines.. Dont know about using them on NA ones though..
Old Feb 23, 2005 | 12:09 PM
.dave's Avatar
i HAS questions ?
Default Re: (tgreaves)
http://boosted-hybrid.com/view...art=0
Full-Race is still working on their intake manifolds last I knew. They should be done sometime in the spring.
Old Feb 23, 2005 | 01:01 PM
Default Re: (entr0py)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by entr0py &raquo;</TD></TR><TR><TD CLASS="quote"> http://boosted-hybrid.com/view...art=0
Full-Race is still working on their intake manifolds last I knew. They should be done sometime in the spring. </TD></TR></TABLE>
awesome man.. thanks for your help? do you know anyone that has run the skunk2 mani? did they like it .. will it perform well and not **** out? thanks!!
Old Feb 23, 2005 | 01:20 PM
DragSource's Avatar
Anyone I have talked to that has ran the skunk is happy with it. . . keep in mind, that they don't really modify the intake runners. . . so you are really just trading a little bit of low end for a little bit of top end.
Good for the 1/4 though.
Old Feb 23, 2005 | 01:53 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DragSource &raquo;</TD></TR><TR><TD CLASS="quote">Anyone I have talked to that has ran the skunk is happy with it. . . keep in mind, that they don't really modify the intake runners. . . so you are really just trading a little bit of low end for a little bit of top end.
Good for the 1/4 though.</TD></TR></TABLE>
thanks for the help!! in your opinion.. do you think its worth it? i just dont like the stock mani.. being 2 piece and all ... and im starting to boost so i just thought it might be time to upgrade....
Old Feb 23, 2005 | 02:03 PM
miro_gt's Avatar
Default Re: (turboH22Aakkord)
How much are you willing to pay for intake manifold ? ... I had a plan to desigh a bigass manifold, like .. with 3" main pipe and 4 x 3/4" pipes to the head ... would come up to about 150 bucks (all almn. pipes) ... will be assembled outside the US
Old Feb 23, 2005 | 03:25 PM
HXMan's Avatar
Anyone have any thoughts on the new BBK manifold?
I know they make nice good working manifolds for mustangs....
Old Feb 23, 2005 | 05:21 PM
.dave's Avatar
i HAS questions ?
Default Re: In need of a lilttle intake manifold advice..... (HXMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HXMan &raquo;</TD></TR><TR><TD CLASS="quote">Anyone have any thoughts on the new BBK manifold?
I know they make nice good working manifolds for mustangs....</TD></TR></TABLE>
Same thing as the Edelbrock, only with a different name stamped on it from what I've heard. Check with Marauder, he works at Edelbrock.
Old Feb 23, 2005 | 06:03 PM
HXMan's Avatar
Default Re: In need of a lilttle intake manifold advice..... (entr0py)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by entr0py &raquo;</TD></TR><TR><TD CLASS="quote">Same thing as the Edelbrock, only with a different name stamped on it from what I've heard. Check with Marauder, he works at Edelbrock.</TD></TR></TABLE>
Well if that is true...I like it. Its only $259 from summit racing.
Summit seems to show a difference...at least in their descriptions.
Victor X powerband: 6,000-10,000 rpm.
BBK SSI powerband: 1,500-7500 rpm.
Old Feb 23, 2005 | 07:16 PM
.dave's Avatar
i HAS questions ?
https://honda-tech.com/zerothread?id=1086755
Old Feb 23, 2005 | 07:35 PM
drift2004's Avatar
eldebrock manifold victor x thats what i got im almost going to boost, but in n/a i seem to lose power here are some link on the manifold
http://www.turbomagazine.com/t...brock/
Old Feb 23, 2005 | 07:43 PM
turbosi03's Avatar
Default Re: In need of a lilttle intake manifold advice..... (drift2004)
ok, my only question is if $300 is a big deal to you, why do you want to buy an intake mani so bad? I mean people are putting down HUGE power with the stock mani... so what do you need a new mani for?
the other thing I'm wondering is how do you have a boosted civic and think spending $300 is a big deal?
Old Feb 24, 2005 | 09:38 AM
Default Re: In need of a lilttle intake manifold advice..... (turbosi03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbosi03 &raquo;</TD></TR><TR><TD CLASS="quote">ok, my only question is if $300 is a big deal to you, why do you want to buy an intake mani so bad? I mean people are putting down HUGE power with the stock mani... so what do you need a new mani for?
the other thing I'm wondering is how do you have a boosted civic and think spending $300 is a big deal? </TD></TR></TABLE>
haha... i'm a broke college student for 1... ( 50 cents is a big deal to me) for 2. i guess i just dont like the 2 piece H22a mani and just thought i might get a little better power out of an aftermarket one... and for 3. i have a boosted accord.. not civic..
PinoyCivic
Aug 3, 2006 09:39 AM
95_red_dc
May 22, 2006 01:28 AM
p1ccoloz
Mar 7, 2003 01:09 AM
EJ8 Kenobi
Aug 2, 2002 11:40 PM
