need help what size injectors for my setup
ok heres my setup i ordered eagle rods, cp pistons 9:5:1 compression, STR block guard, t3 60-1, equal length runners on the turbo manifold, but besides that the rest of my turbo kit is just a stock drag kit what injectors would i need if i want to 420whp im going to let st00pid tune my car but i need to know what injectors to get and im only going for 350whp first and im going to buy hondata im sorry i forgot to mention that and would i need to get anything else on the turbo kit to allow my 350whp like would i need to get a new fmic? sorry for such a long post
900cc is good for 500hp. I go with 900cc. I believe the price for 720 is the same as 900. I go big injectors because you still have a lot more room to play with if need more power in the future.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TURBO B »</TD></TR><TR><TD CLASS="quote">thank you people for all the help. what if i were to go with 880cc what lbs would that be 88lbs? </TD></TR></TABLE>
sounds good to me
sounds good to me
a 72 lb injector is arround 760 cc and a 880 cc inj is arround 84 lb i would go larger on the injector so you can keep the duty cycle down but emember if the car is a street car than its hard to get the big injectors to idle right without loading up the cylders with fuel
hope this helps
hope this helps
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18cls1 »</TD></TR><TR><TD CLASS="quote">a 72 lb injector is arround 760 cc and a 880 cc inj is arround 84 lb i would go larger on the injector so you can keep the duty cycle down but emember if the car is a street car than its hard to get the big injectors to idle right without loading up the cylders with fuel
hope this helps</TD></TR></TABLE>
Even with tuning? Does this affect gas mileage as well?
even with tunning with a stand alone managment when a big injector tries to run a low duty cycle like at idle it has a hard time metering it but once you start to drive again it will clear up its only at the low duty cycles like idleing so if you do allot of stop and go traffic driving you might want to think about it
lakiaccord
Jan 6, 2004 06:06 AM
