Need HELP w/ Fuel Pump
Old Nov 12, 2005 | 01:52 AM
Dan_the_MaN's Avatar
Default Need HELP w/ Fuel Pump
Hey guys, im trying to save money by installing a walbro 255 fuel pump i just bought, can anyone help me with installation. I got the installation kit, but I dont know where to begin. I removed my backseat and I found something, but I dont know if the fuel pump is inside of the 2 canisters I found, or if I have to go underneath the car. If you guys kno any links to where it has step by step instructions, I would much appreciated it. Thanks for all your help.
Old Nov 12, 2005 | 02:19 AM
D@nnY's Avatar
what kind of car is it? most likely the larger one in the middle is the fuel pump and the other is for the sending unit... there will be a circle of 10mm nuts around it and electrical plug and like a 17mm banjo bolt for the fuel line
disconnect that stuff...pull the pump up and out and replace the thing
remove the battery ground first so you dont start a fire
Old Nov 12, 2005 | 02:30 AM
Default Re: Need HELP w/ Fuel Pump (Dan_the_MaN)
o sry about that its a 97 civic lx sedan. thx alot for the advice danny, i kno about the battery, but it says unplug the wires and start the car and let it die. Do i really need to do that?
Old Nov 12, 2005 | 04:29 AM
D@nnY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan_the_MaN &raquo;</TD></TR><TR><TD CLASS="quote">o sry about that its a 97 civic lx sedan. thx alot for the advice danny, i kno about the battery, but it says unplug the wires and start the car and let it die. Do i really need to do that? </TD></TR></TABLE>
the only reason for this would be to relieve the 40 psi system fuel pressure fromt he feed line so i tdoesnt leak into the car...
if the car sits for a while it shouldnt hold the pressure long...just dont click the key foward and prime the pump right before you do it...also when putting the pump back youll see a little box looking thing in the tank the bottom sock has to sit in...youll know what im talking about when you take it out
AZDC4
Jul 20, 2010 10:35 AM
motormike40
Aug 25, 2006 05:27 PM
motormike40
Aug 25, 2006 05:06 PM
yellowrexturbo
Oct 9, 2004 03:36 PM
johnzm
Aug 17, 2002 07:58 PM
