need help turbo gsr please help !!!
Old Feb 21, 2006 | 05:28 AM
TRBODC2's Avatar
Default need help turbo gsr please help !!!
ok i need help from the tech gurus please this is a problem i believe dates back to almost a year my setup is a gsr block darton sleeved je 9.1 comp pistons and crower rods with a stock b16a head i have a sfp manifold sfp 2.5 inch downpipe greddy type s bov and a hks wastegate the car b 4 had a garrett t3t4 turbo on it it smoked a bit so when i got it tuned the first time we all thought the turbo was shot the #'s were 303whp and 225tq @ 16psi which was crazy for the amount of boost but again i figured it was the turbo so now almost a year later i bought a precision sc44 with a 63a/r and we start off slow on the dyno only pushing 8psi but the car only made 201whp at that point i was going crazy so we did not continue the next day i did a comp test it went as follows from 1st to 4th 185-190-190-190 i guess thats good the same day i pressure tested all the piping found one leak fixed it but car still runs like *** i dint know what else to think maybe u guys can help thanks in advance
Old Feb 21, 2006 | 06:27 AM
97CWITR's Avatar
Default Re: need help turbo gsr please help !!! (TRBODC2)
leak down test as well?
you've kept up with replacing the distributor, rotor, etc..etc?
what are u tuning with>?
Old Feb 21, 2006 | 07:04 AM
TRBODC2's Avatar
no leak down test as i was told that if the comp checked out ok that it was not needed and im usung hondata s200
Old Feb 21, 2006 | 01:23 PM
TRBODC2's Avatar
ttt please help
sheepey
Sep 6, 2006 07:51 PM
CO_CReX
Aug 11, 2006 07:12 PM
TRBODC2
Jan 18, 2006 03:21 PM
71 mgb
Sep 28, 2003 10:48 PM
