Need help with S2000 Turbo Project?
Old Jun 15, 2005 | 09:14 AM
extremecorvette's Avatar
Default Need help with S2000 Turbo Project?
Hello guys, I just bought a Honda S2000 rebuilder my self. It's a 02, and it has no motor.
I'm wanting to put a turbo on this car and was wondering what kind of hp and tq on average are people getting?
What is the diffrence in the AP1 and AP2? I know the CR is 11.1:1 I was thinking of building a motor with 8.5-9.5:1 with a forged pistions and rods, what hp can the crank take? I what is the weight of the car? Want to make about 400-450 RWHP, cheap as possable is the key point. I have a bet with brother I can beat his stock Z06 with it once I'm done.
Stock corvette is 3245 lbs
On my 00 corvette I did:
ARE Stage 2 Heads 11:1CR Int 292@550 300@600 Ext 217@550 222@600
LG G5X3 Cam
LS6 Intake
Meziere Electric Water Pump
ASP Underdrive Pulley
Ulf Engineering Ported TB
Howe Racing Long Tube Headers 3” Collector
Borla XR-1 Exhaust No CATS
Vararam Air Intake
ARE Ported Oil Pump
Comp R Lifters
Spec III Clutch / Billet Steel Flywheel
Spec of cam
INT EXH
ADV DUR: 283 291
DUR @ .05: 234 242
VALVE LIFT: .598 .610
The car dyno 420 RWHP and 421 RWTQ
I really want to get into this S2000 project car and kick some corvettes around.
Let me know what you think.
Also what is the largest tire you can fit in the back? Can you get a 295
Old Jun 15, 2005 | 09:18 AM
yellowturbo's Avatar
well you wont have any problem to beat him since almost every 300whp or more Honda with a good driver can beat a Corvette...
But you should remove the word ''cheap'' from you project and always get the best the first time. Get AEM EMS, and soem good rods+pistons, the turbo and the manifold and your set.
Try to PM Tinker219 on this board. I think that he sells a pretty good turbo kit for the S2000 and he have a pretty good customer service too.
http://www.lovefab.com
I do not work for him but I know that his S2000 run pretty good using this kit.
Old Jun 15, 2005 | 10:27 AM
Drag_On's Avatar
Your going to need to do something with the rear end at 400+whp..
Get a hold of Tinker - he's selling his turbo S2k - maybe you'll part out the kit to you.
Old Jun 15, 2005 | 10:32 AM
rough_draft's Avatar
u wont need 400whp to beat a z06
Old Jun 15, 2005 | 10:39 AM
Tinker219's Avatar
Default Re: (Lmaonade)
Im not selling the S unless I get exactly what I want for it. I have parted with a few other things so selling the S is the last to go, which hopefully wont have to happen.
Anyway, yes, we make a great kit for the car. Mine has almost 10k miles with the kit on there, its VERY complete, down to the last hose clamp and with the right options will support 6-700whp.
Stock motor though, you can expect around 320whp on a Mustang dyno, 360whp or so on a dynojet(Ill be strapping down on one soon here).
jrose29
Honda S2000
Sep 16, 2010 03:09 PM
VtecKiDD
Mar 12, 2007 03:04 PM
19sec beast
Jul 5, 2006 01:48 PM
extremecorvette
Honda S2000
12
Jun 16, 2005 03:39 PM
