need help with injectors
i was told the injectors i have are precision 310cc injectors, but i can't find anywhere to prove that. anybody have a place i can e-mail to find out which ones i have?
on one side of the injector it has number: D1720AA
the other side has number: 621020
thanks for any info
thanks for any info
http://orlandospeedworld.com/f...pp=40
http://www.racetronix.com/621020.html
according to those 2 pages, they are stock replacement buick tomco injectors or delphi's. but according to both pages, they are 32 lb/hr, or roughly 310 cc/min's
quick google search for those 2 numbers brought up those pages.
damn... wonder if people used these on honda/acura motors before.
i got them with a s/c kit i bought from somebody on here
people use dsm injectors on honda's, i used ford blue tops in my buick, it isnt uncommon to swap out other make injectors, just ohm them, if they are 2-3 ohm injectors you will need a resistor box, if they are 12-13 ohm, you are fine.
okay... i put the ohm meter on one of the injectors and it came out to 16ohms.. does that sound right?
an obd1 injector clip does fit on these injectors.
so with a 16ohm, these injectors don't need a resistor box, correct?
