need help identifying a turbo?
the turbo is a turbonetics turbo it has a t/4 flange for the exhaust manifold the in take inlet sizxe is 4" but the fan center is 2" the outlet on the cold side say's .50 inside of it the exhaust side say's .53ar or .58ar i cant make it out but where the flange for the manifold is it says .58 inside of it and the downpipe is a round four bolt style thanks for your help.
Please measure Inducer/exducer of the compressor and exhaust wheels. The covers will have to be removed to measure properly. The numbers you've given are generic for A/R of the covers that you are using.
that is a 54 trim 76.2mm exducer (similar to a 57 trim) T4, using a smaller stage II wheel. (based upon the information given). This COULD work, but from the T4 flange, keeping the volute higher with energy based upon your displacement may prevent it from being "enjoyable"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan »</TD></TR><TR><TD CLASS="quote">that is a 54 trim 76.2mm exducer (similar to a 57 trim) T4, using a smaller stage II wheel. (based upon the information given). This COULD work, but from the T4 flange, keeping the volute higher with energy based upon your displacement may prevent it from being "enjoyable"</TD></TR></TABLE>
I think what he is trying to say is "damn thats a big turbo and you gonna need a big motor"
Max McNasty
Apr 28, 2011 01:22 PM
02type-sk20
Aug 4, 2010 11:08 AM
