Need help finding a fitting!!
I am looking for a fitting and can't find it any where, it seems like it would be a common fitting but I guess its not, I am looking for a 12mmx1.25 thread to a -6an, if anyone know's of any manufactures that make it or if you can get it please respond https://honda-tech.com/forums/images/smilies/emthup.gif
Re: Need help finding a fitting!! (jdmcivicferio)
have u tried http://www.mcmaster.com
Summitracing also carries the full product line of Earl's and Aeroquipe fittings. You can call up either of those companies and get a part number than order it from Summit.
Not sure if this thread would help you.
https://honda-tech.com/zerothread?id=373905 Stan may also have your fitting you need. |
Re: Need help finding a fitting!! (Muckman)
I carry every fitting under the sun and I can't find that one. Can you tell us what it's for and maybe i can give you some guidance. It's the 1.25 thread that has me stumped. You might consider a banjo fitting on that.
Re: Need help finding a fitting!! (agrabau)
found it https://honda-tech.com/forums/images/smilies/emthup.gif , now I can complete my fuel lines, I also found the fitting for my clutch being a 12x1.0 -4
I'm going to be doing the same thing. He's getting the AN to metric adapter for on top of the stock fuel filter location (minus the banjo fitting). I found it at Summit racing, part# EAR-991945 (6AN to 12mm x 1.25) It's not listed with the other conversion fittings.
| All times are GMT -8. The time now is 05:48 AM. |
