Need help with F22b turbo setup
Old Jul 7, 2011 | 08:55 AM
despat's Avatar
Default Need help with F22b turbo setup
Hi, I'm in the process of installing a turbo my HOnda. I've only got this a Garrett T3 50trim turbocharger (.48 A/R hot side .42A/R cold side, standard 5 bolts exhaust side) and would appreciate if you could help me with the rest of the set up (what parts I'll need).
I've got lots of reading up to do, however, it would be nice if you could point me to the items that I need to complete the setup. My car is a honda oddy 97 with a JDM f22b 2.2L 4cly 16valve SOHO engine. The car is completely stock and my reason for turbo is just drivabiltiy (no drag racing at high rpm). I believe i chose the right turbo for my purpose (correct me if i'm wrong). My car, being a van (often carrying 7 passengers) drives heavy so I'm not turbing for speed. I just want to increase the trottle response and get some more power for daily drive.
Infact, once installed, I'm planning of tuning for mileage (with a dyno).
Can someone please send me a list of the items that are compatible with my car and the turbo (Garret 50trim 48Ar hot/42Ar cold) that I will need. I plan on keeping my AC in the car and if possible converting the turbo to internal wastegate (if possible with an actuator).
Thank you
Old Jul 8, 2011 | 12:30 AM
JdmTypeRdc2's Avatar
Default Re: Need help with F22b turbo setup
Uhhhh....wrong section
Old Jul 8, 2011 | 06:03 AM
despat's Avatar
Thanks for moving it to the right section.
Anyone???
Old Nov 28, 2011 | 06:29 PM
palmeto21's Avatar
yes you can keep ypur ac , i recomend that you put some termotec on yoour tailgate so it won break your alternator
chitownrida
Mar 29, 2006 09:37 AM
warzo69
Oct 19, 2005 07:30 PM
