Natrium filled valves
Old Sep 29, 2002 | 11:13 PM
austrian type-R's Avatar
Default Natrium filled valves
Whats up with natrium filled valves. I have heard these babys are excelent for heat. Why is no one running such valves on this board?
Old Sep 30, 2002 | 07:44 AM
Madness's Avatar
Default Re: Natrium filled valves (austrian type-R)
sodium filled valves are excellent for high heat applications
i haven't seen any info on sodium filled valves for honda apps
maybe someone more knowledable can enlighten?
Old Sep 30, 2002 | 08:40 AM
twkdCD595's Avatar
Default Re: Natrium filled valves (dante_420)
I am sure you could get something custom or from another application to work, but they are not cheap either way.
The sodium filled that is... but what not expensive these days anyways.
Old Sep 30, 2002 | 08:42 AM
VaporTrail's Avatar
New User
stock honda exhaust valves are sodium filled, hence their high cost.
Old Sep 30, 2002 | 02:17 PM
Default Re: Natrium filled valves (VaporTrail)
realy? Are you sure? The exhaust valves are not sooo much expensiver tah the intakes.
Old Sep 30, 2002 | 03:08 PM
Spankee2K's Avatar
I think you guys are referring to Talcum filled valves. The talcum inside the valves liquifies when the engine is hot to help cool the valve down. Though this seems like a good idea it is mostly used on heavy duty engines such as tractor trailers and such. These valves are prone to more engine damage as they have been known to explode when temperatures rise above normal.
[Modified by PressurizedB18C5, 3:40 AM 10/1/2002]
namewasdallas
15
Apr 30, 2011 04:14 AM
junkyard racer
Sep 7, 2008 04:41 PM
Boostage
Sep 15, 2005 05:35 PM
