my new garrett
Old Nov 28, 2014 | 01:32 PM
chickenbandit's Avatar
Default my new garrett
I recently damaged my pte 6265 and decided to go with a
Garrett t3t67 turbo. I'm still fairly new to forced induction so i
Would like all the info you guys can give me on what to expect from this unit.
Bought off a guy on craigs list for $300 brand new and was a big part on why i went with
This turbo. Found some info on it online but i want to hear from honda techs with eexperance running this turbo. Thanks guys
Its has a t3 flange, 2.5in 4bolt exhaust that i had a 3in vband welded to it.
67mm compressor wheel.
Im also not running a oil restrictor,just a small feed line.
My goal is +650whp
Old Nov 28, 2014 | 01:34 PM
$MIKE$'s Avatar
Default Re: my new garrett
If you paid $300 brand new then it's most likely not a real Garrett turbo.
Old Nov 28, 2014 | 01:41 PM
How can i tell
Old Nov 28, 2014 | 02:07 PM
blackeg's Avatar
i can remember wanting this turbo a while back before i settled for a smaller t3t4 60-1.
you still want a restrictor even with a small feed like -3
Old Nov 28, 2014 | 02:08 PM
accordturb96's Avatar
should have decal with the build info on it and serial numbers
Old Nov 28, 2014 | 03:41 PM
Anybody have an example of this?
Old Nov 28, 2014 | 04:11 PM
TheShodan's Avatar
Moderator
Not necessarily all Compressor covers have the Garrett logo on it. Most do, but not all.
From what I can tell, This is at least using Garrett parts, although it does look like a rebuild, and not a new unit.
1. Backplate. That is a billet backplate used by about 2 different Garrett master distribution companies. I've used these myself.
2. Compressor bolts/ brackets look standard Garrett T04 issue.
3. Turbine wheel looks like a replacement unit. Same count as a Garrett journal bearing, and same stamp, but definitely a replacement.
4. V-band looks decent, but don't count on it being a universal fit with a Garrett v-band. you're going to have to try and match a few weld flanges and v-band clamps to see which it fits. Looks VERY aftermarket
5. Boost reference nipple on the compressor cover is a poor choice for its location despite interweb popularity.
6. Compressor cover definitely looks as though it is an OEM-style sand cast mold. Those tend to be very coarse and unmistakable.
7. Turbine housing doesn't look Garrett at all, but may have been machined to fit.
Not all Garrett's have serial numbers on their compressor backplates or cartridges, especially those of larger mid-framed size, and those that are not OEM use. T67s were typically built to order, and therefore didn't have those serial numbers.
So. will this last? hard to say, but it for sure looks like a rebuilt unit in which they had to at least replace the turbine wheel. If they went cheap and tried to replace T3 components (like heat shields , c-clips and retaining rings,) and didn't use the good T4 stuff, it could fail. The seller easily had about $500 into it, if it is real. so, hard to say. Still a better bet than some eBay ****. So.. might as well give it a shot
Hope that helps. Back to work for me. Later.....
Old Nov 28, 2014 | 04:27 PM
well **** I stand corrected. Thanks man
Old Nov 28, 2014 | 04:46 PM
I had the vband welded on and a friend tapped the nipple on the housing.
Here are some better pics, maybe they'll help you help me with even more info
Old Nov 28, 2014 | 04:51 PM
Old Nov 28, 2014 | 04:53 PM
I dont have my tools so cant take off the compressor side
Old Nov 28, 2014 | 05:55 PM
wantboost's Avatar
Who is Mr Robot?
There's no doubting that's a Garrett/Garrett based turbo.
Run it.
Old Nov 28, 2014 | 05:56 PM
wantboost's Avatar
Who is Mr Robot?
You took the turbine side off but not the compressor? They should use the same 13mm 1/2in socket/wrench
Old Nov 29, 2014 | 06:08 AM
The turbine side's bolts were already loose (finger tight) since the took the cover off to weld on the vband.
Ill get more pics today
rudebwoy's Avatar
I have the same turbo in my garage, it was from my peakboost kit, it has shaft play but still works.
*all I need is a new back plate, its a really great turbo. 440whp 15 psi, on a 1.8l
Old Nov 29, 2014 | 02:41 PM
Comp side
Old Nov 29, 2014 | 05:39 PM
wantboost's Avatar
Who is Mr Robot?
I'll say it again.... Genuine Garrett.
Stop worrying and run it.. or mail it to me and I'll use it lol
Old Nov 29, 2014 | 07:14 PM
TheShodan's Avatar
Moderator
I'll gladly take it if you're in doubt. I could do a few things with that unit.
Old Nov 30, 2014 | 08:31 AM
sure looks nice, certainly not like an ebay turbo
Old Nov 30, 2014 | 08:15 PM
Oh im gonna run it even if it was eBay lol
nytosc
Apr 15, 2008 10:06 AM
AlpineIntegra01
Aug 16, 2005 06:28 PM
vtekthis
Mar 1, 2005 05:48 AM
Civicdrgrcr
Feb 13, 2003 09:16 AM
