my motor!!!!!
ok my car idle fine
drives fine
does not smoke out of the breather filter at idle only when you step on the gas
but my car is smoking alot and smells really really rich and there is a resedue on my fuel rail
at idle it smokes not alot but more than it used too...
defiantley noticible
white smoke too no color to it...
i am taking it in tuesday for the posiiblility if a blown head gasket or ring....
not fun...
drives fine
not fun...
im having a smiliar problem
whats your compression first of all?
If you have oil on your fuel fail, its usually coming from your breather filter...causes could be a bent valve, inproperly seated valve, bad piston rings etc etc. but somehow, you're getting blowby in the head......
i have the same problem and I did a compression check and got
1. 200psi
2. 200ps
3. 200psi
4. 90psi
My car smells like gas and has oil build up on the fuel rail. Do a compression check and see what you get.
art
1. 200psi
2. 200ps
3. 200psi
4. 90psi
art
one slow coupe
Jul 3, 2010 11:28 AM
