is my MAP sensor bad....HELP!!!!
Old Sep 6, 2004 | 06:11 PM
jwcardy's Avatar
Default is my MAP sensor bad....HELP!!!!ASAP
ok, i installed my turbo kit today on my 2002 civic...this is the second one that i have done...previous had no problems...today when i started driving the car, the car would continue to rev after i let off of the gas and the safc2 showed that 0% throttle was open...i killed the car...started it back up, and it continued to idle at 3000 rpm....i noticed that with the car not running but the key turned on that the safc was reading positive pressure from the map..but the car wasnt running...just the key turned on...so i unplugged the map sensor to see if that was it...well the safc read negative pressure like normal....and when i started the car with the map sensor unplugged, the car idled just fine...even drove fine for me to pull it into the garage...since the car ran fine with the map unplugged, does this mean that my map sensor is bad....please help....if so i have to get one from honda tomorrow...if not i have to take the kit off until i figure out the problem cause i cant afford to miss another days work....
Old Sep 8, 2004 | 08:41 PM
PrettyLude's Avatar
is there a missing link in the picture?
MatthewMenze
Engine Management and Tuning
May 1, 2014 01:24 PM
zaks1
14
Dec 4, 2012 10:24 AM
zccr-xsi
Dec 2, 2006 06:22 AM
