MSD btm wiring question
Old Feb 27, 2003 | 10:37 AM
avividmemory's Avatar
Default MSD btm wiring question
Anybody got any diagrams on how to set-up the wiring on an OBD1 distributor and what not...I did a search and came up with nothing...
Or does anyone have a link or step-by-step install instructions...thanks for the help guys...btw, its a MSD BTM for stock ignition...
Kevin
Old Feb 27, 2003 | 10:40 AM
CivicSoul's Avatar
Default Re: MSD btm wiring question (SpoolinLS)
Jackson racing has a write up on it for the obd1 cars. Unfortunatly I have a obd2 so I am still wondering the same question. I should help you
Old Feb 27, 2003 | 10:42 AM
Default Re: MSD btm wiring question (CivicSoul)
is it on their site then? ill check that out...I know I can't find jack on msd's site
Old Feb 27, 2003 | 10:54 AM
anybody know how jackson's btc compares with the msd version...is the wiring basically the same or what...insight would be great
Old Feb 27, 2003 | 06:11 PM
BoostedSi's Avatar
http://www.c-speedracing.com
Old Feb 27, 2003 | 09:22 PM
Default Re: MSD btm wiring question (BoostedSi)
yeah i knew they had something about the msd 6btm, but it doesnt go into any great detail...
Old Feb 28, 2003 | 09:12 AM
ttt...
Old Feb 28, 2003 | 01:57 PM
ion_four's Avatar
If you use the stock coil:
BTM->Distributor
Red to Black/Yellow (coil +) (coming from ICM)
White to White/Blue (coil -) (coming from ICM)
Black to coil - screw (on coil itself)
orange to coil + screw (on coil also)
BIG red to batt +
BIG black to battery -
if you use the MSD coil, connect the small red and black to the new coil and follow inctructions that came with it.
As far as the wires go, you can run them through the port on the back-side of the dist. OR you can just cut a slot in the cap. I have a slot now, but will run it through the grommet next time I change the cap. Ignore the magnetic pick-up that comes off of the btm, as well. I think that is all. Cool? If it's unclear, it's all on the msd site, somewhere...
Old Mar 17, 2003 | 11:33 AM
Default Re: MSD btm wiring question (ion_four)
BTM->Distributor
BIG red to batt +
when we got everything connected the car wouldnt even spark...we took it off and it was fine...
also, what do you mean by BIG black and red? there are only one black and one red wire and they go to the dist...or do you splice those to power/battery also?
turbociv910
Apr 24, 2008 05:24 AM
sander
Dec 29, 2006 11:52 AM
smash fascism
Jul 5, 2005 04:26 AM
N1_c55
Jul 26, 2003 10:20 AM
