Most important FI gauges?
Old Apr 28, 2003 | 09:11 PM
skhonda's Avatar
Default Most important FI gauges?
I'd like to know what gauges are the most critical to monitoring a FI honda, and why.
Old Apr 28, 2003 | 09:14 PM
88ZCRX's Avatar
Default Re: Most important FI gauges? (skhonda)
The two I look at most are EGT, and oil pressure. With boost coming in third.
Old Apr 28, 2003 | 09:15 PM
TurboTegB18c's Avatar
Boost, egt, oil pressure. Paul
Old Apr 28, 2003 | 09:19 PM
TeStUdO's Avatar
Default Re: Most important FI gauges? (88ZCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88ZCRX &raquo;</TD></TR><TR><TD CLASS="quote">The two I look at most are EGT, and oil pressure. With boost coming in third.</TD></TR></TABLE>
true egt to see how lean or rich, how close to detonation. oil pressure in case you spring a leak on an oil feed or return line so you dont spin a bearing or worse. boost to see if you are spiking,creeping, or to see when you reach full boost.
also for me there is the tach, my little cx didnt come with one in the gauge cluster. also very important to me
Old Apr 28, 2003 | 09:31 PM
94dxt's Avatar
Default Re: Most important FI gauges? (00si5)
fuel pressure, oil pressure, boost, a/f, exhaust temp
Old Apr 28, 2003 | 09:37 PM
accordexchange's Avatar
Default Re: Most important FI gauges? (94dxt)
i say boost, oil pressure, and fuel pressure...
Old Apr 28, 2003 | 09:44 PM
skhonda's Avatar
Default Re: Most important FI gauges? (accordexchange)
Hrm.. Well i just bought some defi (non-link) boost and air/fuel gauges, and currently waiting on cash for EGT. I guess in a few months i can buy oil pressure and something else. Thanks for the replies fellas.
Old Apr 28, 2003 | 09:50 PM
turbopanda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94dxt &raquo;</TD></TR><TR><TD CLASS="quote">fuel pressure, oil pressure, boost, a/f, exhaust temp</TD></TR></TABLE>
i'd also add to this a knock meter.. I had one - and saved my engine many many times.
without this meter and the A/F (LambdaLink), I wouldn't be boosting my Honda - its hard to hear detonation when you have an external wastegate dumping to underneath your car
Old Apr 28, 2003 | 10:12 PM
T3T495GSR's Avatar
boost, fuel pressure, egt
Old Apr 28, 2003 | 11:27 PM
Snafu-Si's Avatar
From: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
Default Re: Most important FI gauges? (T3T495GSR)
Boost, Oil pressure, cause oil leaks are by far the MOST common thing I always hear about when poeple go Force Induction. Hey, I had a oil leak, but I didn't know, the only way I knew was I noticed that my oil pressure gauge read a big fat ZERO PSI.
Fuel Pressure
EGT
So in all about 4 gauges
Boost
Oil Pressure
Fuel Pressure
EGT
Old Apr 28, 2003 | 11:43 PM
blufke's Avatar
Default Re: Most important FI gauges? (Snafu-Si)
how much is a knock meter like that?
Old Apr 29, 2003 | 12:14 AM
es four's Avatar
From: You can be my wingman anytime...., Las Vegas, US
Default Re: Most important FI gauges? (blufke)
Oil pressure, EGT, boos.
Old Apr 29, 2003 | 03:58 AM
BROOD's Avatar
Default Re: Most important FI gauges? (integra707)
Boost, EOP, EGT, fuel pressure are my minimum. And like 00Si5 said if you do not have a tach...............well, you will need that.
Old Apr 29, 2003 | 04:06 AM
MiraiZ's Avatar
Default Re: Most important FI gauges? (SLPR)
Boost, EGT, and some kind of knock sensor is really handy!!
Old Apr 29, 2003 | 05:29 AM
danl's Avatar
Banned
Default Re: Most important FI gauges? (turbopanda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbopanda &raquo;</TD></TR><TR><TD CLASS="quote">
without this meter and the A/F (LambdaLink), I wouldn't be boosting my Honda - its hard to hear detonation when you have an external wastegate dumping to underneath your car </TD></TR></TABLE>
I'm currently haveing a discussion with a board member about knock sensors. My feeling is that Knock sensors are great to make sure things are in check. You don't know how many times "little" things have caused my car to detonate. Bad "high octane" gas in foerign towns. I had a fuel pump failure. I had an injector seal leak which caused a boost leak which lead to detonation. I had a hole in my intercooler from a stone. I had a failing injector. I mean, just tons of things. The knock sensor encompases allmost any other gauges. If you EGT is high, you'll knock. If your a/f isn't right, you'll knock. If your timing is astray, you'll knock. If you intake charge is to hot, you'll knock. I'm just trying to let you guys know that a lot of factory turbo guys really do a lot with their knock sensors. THE GN guys, Supra guys, DSM guys, sr20det guys, etc...
Oil pressure, Knock, and boost.
Old Apr 29, 2003 | 05:56 AM
Kyoji's Avatar
Any suggestion on which brand of meters? Any personal experiences with autometer, greddy, or whatever?
Old Apr 29, 2003 | 06:14 AM
KCHybrid's Avatar
Default Re: Most important FI gauges? (danl)
who all makes knock gauges or displays then? I know of the safguard, want to say j&s is the company? cant remember right now.
Old Apr 29, 2003 | 06:17 AM
MiraiZ's Avatar
Default Re: (Kyoji)
I love my Omori gauges...they are inexpensive, sporty, accurate, pleasing to the eye, easy to read, and are full sweep...totally recommend them!
Old Apr 29, 2003 | 06:42 AM
mamaboy's Avatar
Boost, EGT, Oil Press, Fuel Press, and if your wondering about a Knock Amp....HKS has one coming out shortly...check that sucka out.....looks great and affordable compared to the FJO lamba meter.......
Old Apr 29, 2003 | 07:17 AM
twkdCD595's Avatar
something HKS and the word affordable in the same sentence just does not sound right... like an oxymoron.
Old Apr 29, 2003 | 04:34 PM
Rain_man's Avatar
New User
Default Re: Most important FI gauges? (twkdCD595)
I thought that knock meters didn't work will with built engines because forged pistons make noise that a knock meter would interpret as detonation?
I'd get a oil temp if you did any road racing.
Old Apr 29, 2003 | 04:40 PM
MooreBoost's Avatar
i have boost and a/f, could probably use fuel, and oil.
gmoore
Old Apr 29, 2003 | 05:05 PM
danl's Avatar
Banned
Default Re: Most important FI gauges? (Rain_man)
I know the J&S is designed to filter out mechanical noises like this. However, a well built engine shouldn't have any piston slap if all the clearances are maped out correctly and a well designed piston is used. I know for a fact that a lot of guys with factory knock sensors that rebuild their engine with upgraded internals don't have any problems. Not only that, but a lot of factory turbo cars come stock with forged pieces.
Old Apr 29, 2003 | 05:29 PM
slowsi00's Avatar
Default Re: Most important FI gauges? (mamaboy)
is this what your talking about for a knock sensor read out??
Old Apr 29, 2003 | 05:43 PM
dfoxengr's Avatar
boost and EGT thats all.
so u know what ur boosting and so u know how hot ur exhaust gas gets...
