In the mood to start on a daily car project......
Well Im about to start another long adventure
for a daily car I think my friends and I have finally narrowed my decision to something along this line . Sense I'm the last person in the world to make up his mind on anything ( ie : 2jzgte sc300 , sr20det'd 240 , and so on - other chooses that really didnt apeal to me .) I hope you guys can help me out on this one , what do you think about this...
A 96 up civic coupe with a b series more than lickly a gsr built either the ge block riser motor or aebs stage 3 motor with a revhard tubular manifold bolted either to a xs turbo or maybe ITS . managment is gonna be along the lines of FAST or dfi v.7 and the whole nine yards but tell me what you guys would do -thnx-Pdang
for a daily car I think my friends and I have finally narrowed my decision to something along this line . Sense I'm the last person in the world to make up his mind on anything ( ie : 2jzgte sc300 , sr20det'd 240 , and so on - other chooses that really didnt apeal to me .) I hope you guys can help me out on this one , what do you think about this...A 96 up civic coupe with a b series more than lickly a gsr built either the ge block riser motor or aebs stage 3 motor with a revhard tubular manifold bolted either to a xs turbo or maybe ITS . managment is gonna be along the lines of FAST or dfi v.7 and the whole nine yards but tell me what you guys would do -thnx-Pdang
hehe yeah the cresida would be cool but I'v even gotten a tacoma truck with the 2jz i mean possible but its just not floating my boat -I guess im a true honda fan thru and thru . Althought the 2jz is ungodly i just love the feeling when your LEV equipped car takes out a japanese brut
If you have that type of cash you should go ahead and get something nicer like the sc300..unless you don't like luxury stuff, like me.
well the sc300 isnt that far from my reach its just i really dont see myself in one . The only apealling part to me is the motor in no way the shell that also goes for the supra itself and same thing with the 240 but vise versa i like the shell but really dont see myself building either the sr or ka motor if its gonna be 4bangger its gonna be honda
. -Pdang
. -Pdang
take your Nissan's and Toyota's somewhere else.. this is HONDA-tech! However you build your civic coupe, it wont look as nice as mine!!
Hehe yeah Ill give you that it might not look as nice but than agian all your gonna see is my rear end and thats not just my crack-
WHOA...............that's all yall.
Anyway's I hope you get something up and going P. I thought that SC300 was a good idea. What about that?
i like the idea of the turbo EK, but i'd consider the new Haltech E11 thats about to come out. Should compete with even Motec when its released(around sept 10th) and will only go for about 1500. Run down:
* Full 32 bit system
* Comes with mil-spec wiring
* Halwin3 Windows based programming software only - there will be no DOS version.
* Enough drivers to run a V8 with sequential injection AND direct fire ignition. 6-cylinder sequential injection with 6-coil sequential direct fire ignition is no problem.
* Individual injector and ignition trims
* On-board wide band control.
* CAN support
* Injection time down to 0.004ms , ignition timing down to 0.1 degrees.
* Variable load and rpm points. 32x32.
* Full 720 degree phase timing control of injectors with choice of End or Start of Injection.
* TPS, 1,2,3,5 Bar MAP, Air Flow Meter all available as load inputs.
* Advanced throttle pump control, fully mappable.
* Built in firmware update facility and full diagnostics even for the trigger.
* Idle control has a ton more features.
* 3-rotor AND 4-rotor full support. The 20B is completely covered and will run staged and sequential injection along with 6-coil direct fire ignition with full 32x32 map for trail split timing control.
* Those of you with a rotary, the Oil Metering Pump is supported and allows mapping of the oil injection system !
* Dual on-board maps are directly supported.
* On board datalogging. No need for a laptop to be connected to do datalogging. Log rate up to 250 samples per second !!!
* Boost control is 3D mappable.
* Many more trigger systems covered, with an updated internal RA system as well. Motronic support built in.
* 5x Digital Inputs , 4x dedicated PWM with spare outputs available, 2x AuxOuts , 8x Spare A/D inputs.
* CAN support
damn the new haltech sounds nice i was thinking of something that can handle 8 injecotrs and that looks like it can handle it and than some .thnaks-Pdang
Pancho2193
Nov 11, 2011 05:09 AM
