Missing link necessary?
hey guys. Ive got my whole revhard setup and was going have it installed tomrrow. However I don't have a missing link... I was wondering if this would pose a problem. I will only be running 7 psi, but I wanted to check if a missing link HAS to be installed. I was going to order one this weekend and put it in next week so I would only be running without one for about 4 days. I just wanted to get the turbo on this weekend because i can't do it in the week between school and work. Any help is appreciated.
Re: Missing link necessary? (CJJones87)
u will have to use a missing link if u arent running any kind of fuel management.
Re: Missing link necessary? (spoolinup)
Ive got a 12:1 FMU. Is that enough?
No thats not what i meant.i meant crome,uberdata,hondata,aem etc. that type of fuel management.Those programs are meant to read boost ,yer stock ecu isnt.Thats why u use a missing link to trick yer stock ecu so it doesnt read boost.If yer stock ecu reads boost it will go into lymph mode and through a map sensor code.So the to answer yer question,yes get a missing link u need it. https://honda-tech.com/forums/images...es/emsmile.gif
the missing link keeps the MAP sensor from seeing boost. this is why you must have it if you arent running engine management.
Re: Missing link necessary? (hondaxsimike)
just go to a local petsmart or wherever sells oneway checkvalves... for every one checkvalve you can prevent up to 2 pounds of boost from getting to the map sensor... my friend has 4 of these inline to his map sensor and never has map senser problems
goodluck https://honda-tech.com/forums/images/smilies/emthup.gif |
you'll need a missing link or run check valves at the least
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoolinup »</TD></TR><TR><TD CLASS="quote">lymph mode </TD></TR></TABLE>
LOL! |
Re: Missing link necessary? (notoriousB)
Alright. Would I be able to drive the car for less than a week until the missing link gets in the mail or would I be risking blowing my motor or something?
u need the missing link if not the map will see boost and go into limp mode, Check Valves or Missing link, Dont drive with out it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoolinup »</TD></TR><TR><TD CLASS="quote">If yer stock ecu reads boost it will go into lymph mode</TD></TR></TABLE>
Classic!! |
Thanks for the chuckle. https://honda-tech.com/forums/images/smilies/emthup.gif |
i ran my turbo on my GSR without it for a couple of weeks i've even had street races... i heard not a good idea, YEAH when you start to boost in the 4-5 lbs the CEL will come on ...try not to boost to high because your ECU will throw a CEL. drive normal and it'll be fine, after the missing link i had no problem... except for my leaning out, which is a different problem ....
w/o it you will get CEL after a few pounds of boost.. i wouldnt drive it unless you really have to. it should be fine for a few days just go easy on it. ebay https://honda-tech.com/forums/images/smilies/emthup.gif
Re: Missing link necessary? (anguish)
OK. Well from what I'm hearing, it'll be OK for a lil while (I'll only be driving without it for about 4-5 days), so I'll just go easy on it until I get it in. Thanks for all the help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoolinup »</TD></TR><TR><TD CLASS="quote">lymph mode</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notoriousB »</TD></TR><TR><TD CLASS="quote"> LOL!</TD></TR></TABLE> man, you guys don't know hao to spiel! it's lymph node ha ha |
Re: Missing link necessary? (Laserjock)
Re: Missing link necessary? (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman »</TD></TR><TR><TD CLASS="quote">Spell https://honda-tech.com/forums/images...es/emsmile.gif</TD></TR></TABLE>
No, spiel. Like "Damn it! I spieled my beer!" You'll be fine without your missing link as long as you don't try to push it hard. Stay out of boost and you'll be fine. |
Re: Missing link necessary? (nota-eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nota-eg »</TD></TR><TR><TD CLASS="quote">
No, spiel. Like "Damn it! I spieled my beer!" You'll be fine without your missing link as long as you don't try to push it hard. Stay out of boost and you'll be fine.</TD></TR></TABLE> i don't know what is up with all the emotikoontz butt you all jus kneed to ansear da doods kwestyon abowt de messing lynch! |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Laserjock »</TD></TR><TR><TD CLASS="quote">i don't know what is up with all the emotikoontz butt you all jus kneed to ansear da doods kwestyon abowt de messing lynch!</TD></TR></TABLE>
Aye deed. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nota-eg »</TD></TR><TR><TD CLASS="quote">No, spiel. Like "Damn it! I spieled my beer!" You'll be fine without your missing link as long as you don't try to push it hard. Stay out of boost and you'll be fine.</TD></TR></TABLE> |
| All times are GMT -8. The time now is 01:05 AM. |
